Teething troubles
- Maitland
13 Mar 2018 16:20 #107280
by Maitland
Teething troubles was created by Maitland
I'm definitely confused. I have installed NCAM in LinuxCNC (2.7.12) for my flat bed engraver, and I get the tab. But I can't get it to load any of the examples. The open project menu appears, but when I select a project it just sits there. Eventually the menu goes blank, but doesn't go away, and the whole program is hung up. Any idea what I've done wrong?
- Maitland
15 Mar 2018 18:46 #107387
by Maitland
Replied by Maitland on topic Teething troubles
No one seems to have any suggestions so:
- I re-installed the entire LinuxCNC distribution from the live disk.
- I updated LinuxCNC to 2.7.12 using Synaptic.
- I installed NativeCAM by downloading ncam_debsetup.txt, changing to the Downloads directory and typing sudo bash ncam_debsetup.txt
- I changed directory to FlatBed under home/linuxcnc and typed ncam -i FlatBed.ini -t -c mill
- I ran the FlatBed configuration of LinuxCNC
The result this time is that I get a NativeCAM tab in Axis, but it is blank.
If I run NativeCAM as a standalone I get the menus but without any display of the workpiece.
I hope this will give enough information as to what I have done wrong or omitted.
- FernV
- Thank you received: 124
07 Apr 2018 21:30 #108574
by FernV
Replied by FernV on topic Teething troubles
I think you should find the solution from here :
forum.linuxcnc.org/nativecam/33573-nativ...?limitstart=0#101916
Sorry for the delay, I was away
Fern
Fern
Time to create page: 0.820 seconds
