error message
- skrap58
25 Mar 2018 19:01 #107835
by skrap58
error message was created by skrap58
Hello,
I keep getting this error message when starting linuxcnc. Start from terminal attached with a screen shot of linuxcnc.
As always thanks for any and all help.
Bill
Bill
- Thank you received: 1476
25 Mar 2018 20:47 #107842
Replied by Todd Zuercher on topic error message
That is the result of either having a base-thread speed too fast for the latency of the computer or a computer that doesn't have good enough latency.
- skrap58
26 Mar 2018 10:45 #107894
by skrap58
Replied by skrap58 on topic error message
Hi Todd and thank you for the reply. I should have been more specific. This is the error which is the thorn in my side.
/usr/share/linuxcnc/aux_gladevcp/NativeCAM/ncam.py:2644: GtkWarning: IA__gtk_accel_label_set_accel_closure: assertion 'gtk_accel_group_from_accel_closure (accel_closure) != NULL' failed
mi = _action.create_menu_item()
It comes from starting linuxcnc from the terminal.
The realtime error happens no matter what I set the latency at. Once closed it doesn't seem to bother anything. In nativecam some subroutines work and others don't. Just trying to get things tuned so everything works as it should. Also my screen shot was not what I intended. My apologies.
Bill
Bill
26 Mar 2018 14:23 #107900
That looks like a problem with your Gladevcp. But I couldn't tell you exactly what without seeing your files to look for the problem. (Something to do with your H bar for your spindle speed.) A better programmer might be able to tell you exactly what your problem is just from that error message, but not me.
- skrap58
26 Mar 2018 21:18 #107924
by skrap58
Still getting the same message every time I start Linuxcnc. I have tried deleting the ncam directory and restarting but it does not do any good. Any help would be appreciated. Nativecam freezes linuxcnc when i try to run the basic spacer.xml example. I wonder if this has anything to do with my hal file? I have recently added a water cooled spindle and that is when this problem started. Please let me know what files need to be looked at and I will post them also.
Thank you for your continued support.
Bill
Bill
27 Mar 2018 00:19 - 27 Mar 2018 00:20 #107935
I'm pretty sure it has nothing to do with your ncam installation. It is something wrong with your spindle speed indicator. Which would make sense if you say your problem started when you added a new spindle (and probably the speed indicator.)
Last edit: 27 Mar 2018 00:20 by Todd Zuercher.
- skrap58
27 Mar 2018 12:48 #107954
by skrap58
Thanks Todd,
I will have a look at that this afternoon. Maybe the custom.xml is causing some chaos.
Bill
Bill
- skrap58
27 Mar 2018 20:19 #107996
by skrap58
I have deleted the custompanel.xml and the custompostgui.hal files and still experience the same error messge posted above. I'm stumped. Any Ideas?
Bill
Bill
- skrap58
27 Mar 2018 20:24 #107997
by skrap58
This is the section that seems to be causing the problem in ncam.py
def create_menubar(self):
def create_mi(_action, imgfile = None):
(line 2644) mi = _action.create_menu_item()
if imgfile == None :
mi.set_image(_action.create_icon(menu_icon_size))
else :
img = gtk.Image()
img.set_from_pixbuf(get_pixbuf(imgfile, add_menu_icon_size))
mi.set_image(img)
return mi
else :
img = gtk.Image()
mi.set_image(img)
return mi
- skrap58
28 Mar 2018 11:48 #108029
by skrap58
I'm at the point where I am considering a complete delete and reinstall of linuxcnc and nativecam. I was hoping to avoid that but, I need my machine running. Does anyone have any ideas how I might fix this without the above mentioned steps?
Bill
Bill
Time to create page: 0.702 seconds
