NativeCAM Blocks of Code as Callable Subroutines
- yeltrow
- Thank you received: 3
27 Mar 2018 20:27 #107998
by yeltrow
NativeCAM Blocks of Code as Callable Subroutines was created by yeltrow
I love nativecam. One thing that would make me love it even more, would be if I could "call" a code group so I could do something like change work offsets and run a chunk of the program again. It appears that the gcode that is currently generated by nativecam has conditionals for enabling a block of code, and that those prevent one from being able to use call to kick off that block of code again. Does anyone have any ideas on how I can take groups and treat them like a callable routine? I have a nice program that I would like to automatically run in several different locations on a fixture.
Thanks!
Thanks!
- FernV
- Thank you received: 124
07 Apr 2018 21:15 #108573
by FernV
Rectangle array can repeat your code after offsetting but it is limited to even X or Y spacing. If you want different spacing, use 'Offset/Rotate' group and add your code then duplicate the group as many time as needed. De-activate when not needed.
Experiment with Groups
Regards
Fern
P.S. Sorry I could not answer before, I was out of country.
Replied by FernV on topic NativeCAM Blocks of Code as Callable Subroutines
... if I could "call" a code group so I could do something like change work offsets and run a chunk of the program again. It appears that the gcode that is currently generated by nativecam has conditionals for enabling a block of code, and that those prevent one from being able to use call to kick off that block of code again. Does anyone have any ideas on how I can take groups and treat them like a callable routine? I have a nice program that I would like to automatically run in several different locations on a fixture.
Regards
Fern
