NativeCAM Speed Overrides Might Not Be Safe
- BrendaEM
- Thank you received: 120
04 Jul 2018 01:08 #113361
by BrendaEM
NativeCAM Speed Overrides Might Not Be Safe was created by BrendaEM
I worry about the default preference speed overrides. I feel that nothing should be above 100%, for safety sake.
Thank you for your consideration,
--BrendaEM
--BrendaEM
- Thank you received: 7481
04 Jul 2018 06:08 #113389
Replied by tommylight on topic NativeCAM Speed Overrides Might Not Be Safe
I set that to 200% on all my machines, just in case.
- BrendaEM
04 Jul 2018 17:35 - 04 Jul 2018 17:48 #113430
by BrendaEM
Replied by BrendaEM on topic NativeCAM Speed Overrides Might Not Be Safe
That is humor, correct?
The first non-touched test of my CNC over a small pocket in a scrap of plywood. As you know the Gcode created by NativeCAM controls the spindle dynamically during the cut. It requested 26,000 rpm. I think that the VFD likely would not agree to accommodate that, but if it did, that would be my motor, right there.
Then I thought: what if I was using a Bridgeport or benchtop mill, and surfacing with a flycutter, an unbalanced tool which is not an unusual operation to do with the surfacing operation in NativeCAM. I would not want to run a fly cutter at 130% speed.
The dynamic speed system in NativeCAM is pretty sophisticated for an ad-hock improvisational milling program, but with myRonco Huanyang VFD, I run the spindle at a constant RPM so the current draw doesn't ramp up often.
No, I don't trust my VFD as far as I can throw it. It's pretty light, grasps well, and should go for some distance. With a brittle plastic housing and circuit and heavy metal heatsink inside, It would make a satisfying sound when it hits the pavement.
As you know, I am such a proponent of NativeCAM, that I've given it a standard place in my user interface design.
Last edit: 04 Jul 2018 17:48 by BrendaEM.
04 Jul 2018 18:59 #113435
No it is not humour, i actually set all my machines to go to 200% feed over ride.
As for spindle that should be programmed in the VFD so it can not go past what the spindle motor can handle, although i have pushed some 3000 RPM ones to over 4500 without complaint.
Fly cutter at 130% is .....well depends, on a mill that can do max 500 RPM that is still good, but on a mill that does 6000 RPM ( a Hurco i am working on ) that would be to much, but also dependent on the size of the fly cutter.
- FernV
- Thank you received: 124
04 Jul 2018 19:32 #113439
by FernV
The concept of NativeCAM is to let anyone set it's preferences to what he/she likes.
I never had a complaint about this and only a few comments on this.
When you go through feed and speed tables, you will note that at 100% tool engagement, it is slower than at 50%. So with the option, anyone can do what he/she likes. If they want no override, they simply set it to 1.0.
There is no way I am going to remove the option.
What is the reason you do not do it if you do not like it ?
Fern
Replied by FernV on topic NativeCAM Speed Overrides Might Not Be Safe
Fern
The following user(s) said Thank You: BrendaEM
- BrendaEM
04 Jul 2018 21:45 - 05 Jul 2018 01:00 #113444
by BrendaEM
I am sorry if I wasn't clear. I would never suggest removing such a useful option. I am glad and impressed that it is there : )
"....The dynamic speed system in NativeCAM is pretty sophisticated..."
It was the default value being greater that 100% that worries me. People may run tools at the threshold/border of their maximum RPM.
It's not mine, but fly cutters like this worry my at over 100%, actually over 50% : )
BTW, thank you for NativeCAM. It's a great addition to LinuxCNC.
Last edit: 05 Jul 2018 01:00 by BrendaEM.
Time to create page: 0.094 seconds
