How to create tool set and more
- Ottao.
24 Jul 2018 05:57 - 05 Aug 2018 20:05 #114728
by Ottao.
How to create tool set and more was created by Ottao.
Hello! I don’t know how to creat a tool set in NativeCam. I see the default ones like 0-None 1- 1/16 inch and so on. I would like to create a personal tool set for example a ball nose tool or a v-shape or various diameter mill cutter in mm.
I don’t know how. please help.
thank you
-O-
thank you
-O-
Last edit: 05 Aug 2018 20:05 by Ottao..
- FernV
- Thank you received: 124
24 Jul 2018 12:12 #114745
by FernV
Replied by FernV on topic How to create tool set
Tool table is created in Linuxcnc.
File->Tool table
All info available in lcnc documentation
Fern
File->Tool table
Fern
- Ottao.
04 Aug 2018 08:46 - 04 Aug 2018 10:59 #115596
by Ottao.
Replied by Ottao. on topic How to create tool set
Thank you very much! Another thing: is it possible to create a pyramid in NativeCam? so is it possible to cut along z axis setting an angle, not just perpendicular. how can I do it? thanks for all
Last edit: 04 Aug 2018 10:59 by Ottao..
- FernV
04 Aug 2018 18:09 #115612
by FernV
Fern
No...is it possible to create a pyramid in NativeCam?
Not yet...is it possible to cut along z axis setting an angle, not just perpendicular
Fern
- Ottao.
05 Aug 2018 20:03 #115646
by Ottao.
Ok so maybe I can try to import a gcode of a pyramid for example and adjust it using nativecam (maybe scale it or setting on top of a nativecam drawing?!) Anyway thank you for the quick response and for the amazing work! I am a big fan of you!
- FernV
06 Aug 2018 16:37 - 06 Aug 2018 16:57 #115677
by FernV
ex : the order would be 'material', 'tool change', 'group offset' then in 'group offset.items ' add 'Insert a G Code File' then select the file you just wrote.
Fern
P.S. Do not create your file as a 'sub'-'endsub', just the code needed
You can use 'Miscellaneous->Insert a G Code File' after a 'toolchange' and include all code needed for what you want. You can pass up to 6 parameter values with current version.... maybe I can try to import a gcode of a pyramid
ncam can not scale your code but I recommend you start at X0, Y0 and wrap in a "Group Offset" to move/rotate it around...and adjust it using nativecam (maybe scale it or setting on top of a nativecam drawing?!)
Fern
Last edit: 06 Aug 2018 16:57 by FernV.
Time to create page: 0.193 seconds
