CSS below 100 not possible
- mydani
- Banned
- Thank you received: 9
02 Jan 2019 17:48 - 02 Jan 2019 17:48 #123344
by mydani
CSS below 100 not possible was created by mydani
Hello all (Ferm),
when trying to enter a CSS less than 100 for turning, it is automatically set to a minimum of 100.
Is this intended?
streamable.com/8exq5
Regards,
Daniel
Is this intended?
Regards,
Daniel
Last edit: 02 Jan 2019 17:48 by mydani.
- FernV
- Thank you received: 124
02 Jan 2019 22:18 #123365
by FernV
Replied by FernV on topic CSS below 100 not possible
Hi Dan,
Right click on the parameter/field and select 'Change to gcode'. You will be able to enter anything you like
Fern
Fern
- Thank you received: 4654
06 Jan 2019 19:10 #123621
Replied by andypugh on topic CSS below 100 not possible
100 as a minimum seems too high. Especially if using high-speed steel tooling.
I don't often go as high as 100, in fact, in metric units.
The following user(s) said Thank You: FernV
Time to create page: 1.018 seconds
