Nativecam Embedded for Ubuntu 12.04 RTAI Linuxcnc
- ktchk
25 Jan 2019 07:22 #124796
by ktchk
Nativecam Embedded for Ubuntu 12.04 RTAI Linuxcnc was created by ktchk
Hello FernV
I did installed Nativecam to Debian 9 rt preemptive Linuxcnc 2.7.14 successfully. Thanks for your hard work.
The rt preemptive need a faster cpu. I usually use Ubuntu 12.04 RTAI.
When I install the deb to my Ubuntu Linuxcnc, embedded does not work. Stand alone version, when I call up Nativecam,
no ini file found, and the Linuxcnc tool table does not reflect to Nativecam.
Please see if I can use Ubuntu in stead of Debian.
Thanks in advance
k.t.chan
Thanks in advance
k.t.chan
- FernV
- Thank you received: 124
30 Jan 2019 18:24 #125315
by FernV
Replied by FernV on topic Nativecam Embedded for Ubuntu 12.04 RTAI Linuxcnc
You may find your solution if you start here
forum.linuxcnc.org/nativecam/33573-nativ...-tab?start=10#124323
Fern
Fern
- ktchk
31 Jan 2019 07:49 #125375
by ktchk
Replied by ktchk on topic Nativecam Embedded for Ubuntu 12.04 RTAI Linuxcnc
ncam --tab does not work, -t works
Debian 9 linuxcnc 2.7.14
- ktchk
02 Feb 2019 07:25 #125525
by ktchk
Make a shell script to call linuxcnc and ncam. Working with Debian and Ubuntu, no need to fight with tab any more.
- FernV
05 Feb 2019 15:28 #125743
by FernV
Are you saying you wrote a script for that or you want me to do it ?
I do not know scripting language and can not learn how to do it now, sorry.
Fern
Fern
- ktchk
05 Feb 2019 18:51 #125752
by ktchk
Hi Fern
I just edit startncan.sh that is
linuxcnc linuxcnc/configs/ncam/ncam.ini & ncam -i linuxcnc/configs/ncam/ncam.ini -c mill &
made it executable
It will call up linuxcnc and ncam side by side. Debian and Ubuntu
k.t.chan
made it executable
k.t.chan
