Ncam Facing subroutine bug
- freemoore
- Thank you received: 15
06 Feb 2019 12:47 #125800
by freemoore
Ncam Facing subroutine bug was created by freemoore
Hi. Thanks, as always, for NCAM, I use it all the time and it's brilliant.
Not sure if this is the right place for a bug report but: the Facing subroutine will allow me to choose bidirectional or unidirectional when the Axis setting is X Axis, and unidirectional only if it's on Y Axis. If I try to set Y Axis, Bidirectional, I get 'gcode error in ncam.ngc Near line 168 of .../scripts/ncam.ngc: Parameter is readonly' - any way to fix this?
All the best
Andy
All the best
Andy
- FernV
- Thank you received: 124
06 Feb 2019 15:42 #125815
by FernV
Replied by FernV on topic Ncam Facing subroutine bug
Hi Andy,
Are you using linuxcnc as root ?
Fern
Fern
- freemoore
06 Feb 2019 16:28 #125821
by freemoore
Replied by freemoore on topic Ncam Facing subroutine bug
I don't think so; launching from the desktop icon rather than using sudo from a terminal so I guess I'm not root.
- FernV
11 Feb 2019 18:44 #126212
by FernV
I do not think the problem is in NativeCAM but something with your setup...
When was it installed ? Have you had other issues ?
Fern
Fern
- annuello
13 Mar 2019 10:31 #128499
by annuello
Replied by annuello on topic Ncam Facing subroutine bug
Hi Fern,
I've installed NativeCAM earlier this week. Thank you for your wonderful work and videos.
I've observed an additional Surface Finishing (Facing) use-case which will cause Axis to lock up, requiring a "kill -9 <procId>" to terminate Axis.
Scenario: I have an initial Workpiece (Raw Material) and End Mill Change in the NativeCAM tree. My intent is to create a "decking" pass to clean up the top stock surface, using a single Z-height depth of cut. I add a Facing (Surface Finishing) operation.
To recreate the lockup in the Facing operation:
CutStart = Surface
CutDownTo = -1
StepDown = -1
LastCut = -1
The bug: Axis locks up when CutDownTo and LastCut have the same value. The lockup only occurs when using NativeCAM within Axis. No lockup observed when running NativeCAM in stand-alone mode.
Through trial and error I believe I should set LastCut to 0 to achieve my desired single Z-height depth of cut. However, I'm sure no one wants Axis/NativeCAM to lock up, even with bad user data.
NativeCAM v0.1.14b
LinuxCNC v2.7.14
Debian Wheezy
Yours,
Annuello.
CutStart = Surface
CutDownTo = -1
StepDown = -1
LastCut = -1
NativeCAM v0.1.14b
LinuxCNC v2.7.14
Debian Wheezy
Yours,
Annuello.
- FernV
13 Mar 2019 13:35 #128513
by FernV
Thanks Annuello,
I will address this
Fern
I will address this
Fern
14 Mar 2019 14:00 #128584
Replied by andypugh on topic Ncam Facing subroutine bug
This sounds like an infinite loop with an increment of zero.
(So what is actually locking up is the graphical preview, though the real code would also run for ever)
Time to create page: 0.079 seconds
