ncam.ngc not reloadend when ncam is used in tab
  • twoflowers
  • twoflowers's Avatar Topic Author
  • Visitor
  • Visitor
25 May 2020 14:30 #168872 by twoflowers
Maybe someone can put me in the right direction: When I have ncam installed as a tab, I need to reload the ncam.ngc manually to see changes. when not used as a tab, changes are visible instantly. Also I need to set "OPEN_FILE" to load ncam.ngc on startup.
ncam as tab:
EMBED_TAB_NAME = NativeCAM
EMBED_TAB_COMMAND = gladevcp -x {XID} -U --catalog=mill /usr/share/linuxcnc/aux_gladevcp/NativeCAM/ncam.ui
#GLADEVCP = -U --catalog=mill /usr/share/linuxcnc/aux_gladevcp/NativeCAM/ncam.ui
OPEN_FILE = /home/nik/linuxcnc/configs/Holz/ncam/scripts/ncam.ngc
ncam not as tab:
#EMBED_TAB_COMMAND = gladevcp -x {XID} -U --catalog=mill /usr/share/linuxcnc/aux_gladevcp/NativeCAM/ncam.ui
#OPEN_FILE = /home/nik/linuxcnc/configs/Holz/ncam/scripts/ncam.ngc
Any idea what I have to do to get automatic refresh working?
26 May 2020 08:14 #168945 by bbsr_5a
what version you are on and what base system OS
seams to be a internal interpreter issue on the tab TASK
  • twoflowers
  • Visitor
  • Visitor
26 May 2020 08:27 #168948 by twoflowers
Replied by twoflowers on topic ncam.ngc not reloadend when ncam is used in tab
LinuxCNC 2.8 on devuan beowulf.
Any chance to get that fixed? Otherwise I'm thinking of a workaround with inotifywait + axis-remote --reload
  • twoflowers
  • Visitor
  • Visitor
16 Jun 2020 21:06 #171880 by twoflowers
At last I wrote down the error message: It says "can't do that (EMC_TASK_PLAN_SYNCH) in auto mode with the interpreter idle", as soon as NCAM tries to persuade axis to reload ncam.ngc. What causes this and is there a simple solution for it?
