Flow Chart of the NCAM Script
28 May 2020 22:27 #169258 by Barry
Flow Chart of the NCAM Script was created by Barry
Does anyone know where I can find a Flow Chart of the NCAM script showing at a high level how it works, the file location for the main body of the program and locations of all subroutines it calls etc.?
Thank you, Barry
29 May 2020 06:33 #169269 by Clive S
Replied by Clive S on topic Flow Chart of the NCAM Script
Thank you, Barry
I know this is an old version but might help. forum.linuxcnc.org/nativecam/39192-nativecam-101#169230
The following user(s) said Thank You: Barry
29 May 2020 06:51 #169272 by bbsr_5a
Replied by bbsr_5a on topic Flow Chart of the NCAM Script
as you are in a real mashine it is simply selfdiscriping
you press a icon that lebels the procedure you want to take action and this is called into the DASH
as simple as it is
WYSIWYG
29 May 2020 08:14 #169287 by fixer
Replied by fixer on topic Flow Chart of the NCAM Script
Look at the .cfg files. Those are pretty simple. NGC subroutines that gets called from there on the other hand do become quite complicated with deep nesting levels... I heard a rumor that they will be replaced with more simple pythonic g code generators soon.
Time to create page: 0.090 seconds
