auto mode and parameter file errors on linuxcnc startup
- lllars
- Thank you received: 3
10 Oct 2020 03:20 #185542
by lllars
auto mode and parameter file errors on linuxcnc startup was created by lllars
I'm getting a couple errors after adding native cam to gmoccapy. I've got it set up as a tab. Things seem to work ok after I close those error messages, but I'd rather not have to see them on every startup. Any idea what is wrong?
Screenshot, terminal output, and ini file attached.
- lllars
10 Oct 2020 15:19 #185609
by lllars
Replied by lllars on topic auto mode and parameter file errors on linuxcnc startup
One guess is that these errors are related to ncam.ngc getting automatically loaded when starting linuxcnc. Is it possible to disable that behavior? I have tried going into gmoccapy settings and selecting "none" or a different gcode file to be loaded on startup, but that has no effect: ncam.ngc is always loaded no matter what I do. I'm only going to be using nativecam occasionally, so I would prefer it not to be doing anything automatically.
- mydani
- Banned
- Thank you received: 9
11 Oct 2020 20:52 #185752
by mydani
Replied by mydani on topic auto mode and parameter file errors on linuxcnc startup
Hi
The Problem is the auto generation which was buggy. Please try to disable auto refresh and restart.
If it does not work you can maybe try my version and see whether it works - currently developing some more changes on a branch of Ferms repository.
Regards
Daniel
Regards
Daniel
