Nativecam running on 2.9.4 almost so close
1 year 2 months ago #333779 by Doug Crews
Hello everyone,I managed to get Nativecam loaded and running on the 2.9.4 iso, using the github.com/freemoore/NativeCAM download, and Giovanni’s instruction pdf plus all the corrections along the way. I ran a huge victory lap when I saw the Nativecam Tab in Axis not blank but how it supposed to look! But…..as usual the fight is not over and my troubleshooting skills are limited by my total lack of experience with Nativcam as I have never used it before.The problem is the Nativecam project is not dynamically updating in the Axis preview ,tab and if I try exporting the project as gcode the .ngc file is mostly composed of stuff that looks like this:
(begin Workpiece)(workpiece definition author : Fernand Veilleux) #<wp_width> = [5.906000]#<wp_length> = [13.780000]#<wp_depth> = [0.125000]#<wp_wall> = [0.000000]#<wp_corner_radius> = [0.000000]#<wp_inside_width> = [#<wp_width> - #<wp_wall> * 2]#<wp_inside_length> = [#<wp_length> - #<wp_wall> * 2] #<wp_x> = -2.953000#<wp_y> = 0.000000 o<select> CALL [31] [0] [-2.953000] [-2.953000 - #<wp_length> / 2] [-2.953000 - #<wp_length>]#<wp_left> = #31#<wp_right> = [#<wp_left> + #<wp_length>]
I’ve been asking the AI questions about how Nativecam is supposed to work and I think its been mostly correct but is often describing how it “used to work” and not necessarily how it works now. My gut tells me the problem has something to do with a symbolic link or a missing ncam.ngc file. Any thoughts are greatly appreciated!-Doug
1 year 2 months ago - 1 year 2 months ago #333781 by Aciera
NativeCam has always output gcode in parametric form because it uses subroutines for it's operations (ie the output does not look like what you would expect on a regular 'CAM'). SO there may actually be nothing wrong with that output (except of course that it would need to be formatted properly)
Last edit: 1 year 2 months ago by Aciera.
1 year 1 month ago - 1 year 1 month ago #335632 by BigDo
[img
I'm trying to reinstall LinuxCNC on Debian 12, but I can't get NativeCam to work. I'm missing the menu and actions in the left pane. Does anyone have any ideas?
Screenshot
www.directupload.eu/file/d/9058/zm3mxqeh_png.htm
Last edit: 1 year 1 month ago by BigDo.
1 year 1 month ago #335643 by Giovanni
I suppose you are using German as interface language.
Have you tried to use English?
The following user(s) said Thank You: BigDo
1 year 1 month ago - 1 year 1 month ago #335650 by BigDo
Thanks for reply. I just tried it, and the NativeCam tab remains completely empty.
1 year 1 month ago #335655 by BigDo
I completely reinstalled Linux with linuxcnc in English but the result remains the same.
Time to create page: 0.649 seconds
