Nativecam running on 2.9.4 almost so close
1 year 4 weeks ago - 1 year 4 weeks ago #335695 by BigDo
Giovanni, the default_template.xml file was missing. I used your file from the other thread and now the menu and workspace appear, but I can't add a tool change. The following error message appears when I start linuxcnc in the terminal.I looked at the tool-change.cfg, and it says version=1.15, while the other cfgs say version=1.14.And one more point: in an old default_template.xml from 2019, there are two sections:
1. workpeace
2. tool-change
Last edit: 1 year 4 weeks ago by BigDo.
1 year 4 weeks ago - 1 year 4 weeks ago #335712 by BigDo
I think something is wrong with these 2 cfg files
turning.cfg
tool-change.cfg
both don't work, the rest seems ok
File "/usr/lib/python3/dist-packages/ncam.py", line 1914, in from_src
exec(self.attr["init"])
File "<string>", line 2, in <module>   <<<<<<<<<<<<<<<<<<<<< Which module??
NameError: name 'parent' is not defined. Did you mean: 'reparent'?
Only in this files, "parent" is used.
I deleted these blocks with "parent" as a test, and it worked. However, I don't know what the potential effects might be; I'm not familiar with this.
1 year 4 weeks ago #335797 by Giovanni
The following user(s) said Thank You: BigDo
Time to create page: 0.073 seconds
