- GCode and Part Programs
- CAD CAM
- NativeCAM
- NativeCAM Problems with Program Start after transfer to Control
- hermann1976
- Thank you received: 17
28 Sep 2026 17:48 #349963
by hermann1976
NativeCAM Problems with Program Start after transfer to Control was created by hermann1976
Hello everyone,
I have installed the latest version of NativeCAM under the Gmoccapy user interface of LinuxCNC. So far it works, but every time after transferring a new program to the control, I always have to press the start button twice to launch the program.
The first time I press it, the milling spindle starts briefly, stops immediately, and then I receive several error messages:
What could be the cause of this error?
Thank you very much in advance for your help.
- invalid parameters in linear command
- linear move on line 38 would exceed positive limit of axis/joint 2
- linear move on line 38 would exceed positive limit of axis/joint Z
- Thank you received: 7496
29 Sep 2026 01:09 #349970
Replied by tommylight on topic NativeCAM Problems with Program Start after transfer to Control
What do you mean by "new program to the control" ?
Do you have 2 PC's running this and the one at the machine has issues, or what exactly?
Can you do a short video and upload to youtube or google drive?
- hermann1976
29 Sep 2026 06:29 - 29 Sep 2026 16:17 #349975
by hermann1976
Replied by hermann1976 on topic NativeCAM Problems with Program Start after transfer to Control
No, i mean when i push the Button on the left upper corner in NativCAM then the Programm will load autmomaticly in linuxcnc in program drive.
The video:
The video:
Last edit: 29 Sep 2026 16:17 by hermann1976.
- CAD CAM
- NativeCAM
Time to create page: 0.170 seconds
