micknucam wrote: You don't need to use the second PWM i got rid of it and used an OR gate, this is my hal file but i don't have a tool changer attached !!
MrJTJinx wrote: the intent is to use an arduino to mux the pins (limits only arduino) and generating a frequency is easy when i /we can figure out what PP will accept on the single door input pin. we dont actually know if there is 0v or 5v default on the pin and then a frequency applied for triggered switch or if a frequency is derived from a BCD type of affair - the table of frequencies are in the HAL for 1 to 15 inputs but we have no idea how to apply it to the pin (16). If someone could explain what is supposed to happen that would be most excellent.
its hard not to get mixed up with the % of pwm for tool selection, that part has been resolved.
