setting up for Parallel port Tutoral Part 3
- cncbasher
- Thank you received: 202
28 Aug 2016 10:24 #79585
by cncbasher
Replied by cncbasher on topic setting up for Parallel port Tutoral Part 3
Dinyo:
your a bit sparse on details , we need to know , what the charge pump requirements are , is this for a mesa 5i25 or parallel port etc
but yes pathpilot does have a chargepump , Classic ladder is part of lcnc so should also be in pathpilot , but again easily added .
The following user(s) said Thank You: dinkata
- dinkata
28 Aug 2016 12:57 #79590
by dinkata
1."Chargepump" is necessary for paralel port .Configuration parallel port ,step motor Geckodrive G540.
2.ClassicLadder is necessary for configuration 5i25 + 7i77 .
Can you help me for two things ?
Replied by dinkata on topic setting up for Parallel port Tutoral Part 3
thanks for the replywe need to know
- cncbasher
28 Aug 2016 13:45 #79591
by cncbasher
Treat the chargepump exactly the same as for linuxcnc , chargepump.comp is included in pathpilot
as is classicladder , so if you have a config for linuxcnc , you should be able to copy the approprate sections across.
- dinkata
28 Aug 2016 13:57 #79592
by dinkata
in hal ....# loadrt charge_pump .... run normal .
in hal only .... loadrt charge_pump ...error
io started
halcmd loadusr io started
halcmd loadusr -Wn halui halui -ini /home/operator/tmc/configs/tormach_mill/mill_pp.ini
mill_pp.hal:10: Can't find module 'charge_pump' in /home/operator/tmc/rtlib
2271
Killing linuxcncsvr
Killing task linuxcncsvr, PID=2271
.......................................Please Log in or Create an account to join the conversation.
- cncbasher
28 Aug 2016 14:46 #79594
by cncbasher
check that charge_pump.ko is in /tmc/rtlib
it also should be used in base thread
it may be the version you have has not had chargepump added to the compiled source
please kindly attach your ini & hal file ,
which version of pathpilot are your using
- dinkata
28 Aug 2016 14:59 #79595
by dinkata
There is no such file charge_pump.kocheck that charge_pump.ko is in /tmc/rtlib
instal 1.9.2b and upgrade 1.9.6bwhich version of pathpilot are your using
- dinkata
28 Aug 2016 15:07 #79597
by dinkata
- dinkata
28 Aug 2016 16:02 #79600
by dinkata
thank you , in test runs , later check of machine .
Best regards
Dinyo
Best regards
Dinyo
- X123
05 Jan 2017 04:22 #85271
by X123
Replied by X123 on topic setting up for Parallel port Tutoral Part 3
HI,
I'm new to Pathpilot and just acquired a disk for it.
Read as many install tutorials I could find but I'm baffled. Left shift and left alt doesn't work when the splash screen shows up. After a few seconds it goes right to " Mesa interface card not detected.....etc."
Tried several times but no luck.
Would appreciate any suggestion on how to get past that.
Thanks, Fritz.
Thanks, Fritz.
- cncbasher
05 Jan 2017 09:12 #85275
by cncbasher
theirs a number of things this can be , however my guess is your using an old motherboard and perhaps a USB or wifi keyboard , use a ps2 keyboard and it should work fine , then once the settings have changed to the USB keyboard , then you should be ok . this is more to do with motherboard bios and OS , than pathpilot it's self .
