2.0 install overtop of 17.3
- mooser
- Thank you received: 15
26 Dec 2017 04:34 #103613
by mooser
2.0 install overtop of 17.3 was created by mooser
I'm attempting to do a 2.0 install and failing miserably
1100 mill but non-tormach controller. (hp)
The PP2.0 USB will not boot on this controller or it's sister (another hp) but a "normal" linux USB boots and installs fine, and this PP USB will boot on another asus machine just fine.
Would / should it be possible to install linux 17.3 and then "restore" PP off the USB without needing to boot from it?
M
M
- smgvbest
- Thank you received: 51
26 Dec 2017 07:10 #103619
by smgvbest
Replied by smgvbest on topic 2.0 install overtop of 17.3
The USB stick like the DVD has a GHOST image on it. so if you can find a way to restore that image i'm sure you could. keep in mind the ghost image is specific to that utility. you can't to my knowledge dd a ghost image.
