19" Touchscreen
08 Jan 2018 00:31 #104138 by Strip
19" Touchscreen was created by Strip
I bought a 19" touchscreen without doing enough research on it. It works except the arrow will not track my stylus. when I drag the arrow moves in the opposite direction of my finger. Can this be fixed or did I waste $260? I did do the admin touchscreen calibration.
08 Jan 2018 03:05 #104142 by smgvbest
Replied by smgvbest on topic 19" Touchscreen
Which touchscreen did you get?
when you do a ADMIN TOUCHSCREEN does it identify yours correctly
I don't have one so mine shows this
ADMIN TOUCHSCREEN
list of xinput devices:
"pointer"       id=0    [XPointer]
"keyboard"      id=1    [XKeyboard]
resetting currently set calibration data in xinput
xinput set-int-prop "eGalax Inc. USB TouchController" "Evdev Axis Calibration" 32 0 2047 0 2047
unable to find device eGalax Inc. USB TouchController
xinput list-props "eGalax Inc. USB TouchController"
Error: No calibratable devices found.
you can check the ~/gcode/logfiles for both the
pathpilotlog.txt & xinput_calibrator.pointercal.log
if you can paste the realavant messages might be able to help
ultimately it will probably be running xinput to set it up corectly
08 Jan 2018 05:03 #104147 by Strip
Replied by Strip on topic 19" Touchscreen
Thank you for your reply. it seems to work fine except the the pointer moves in the opposite direction of the stylus. ie if I drag toward top right, it goes towards bottom left. it even acts like it calibrates correctly.
This is the one I bought www.ebay.com/itm/19-5-Wire-Touchscreen-L...d66:g:-t0AAOxycERRkj
I will check the log files. Thank You
08 Jan 2018 05:21 #104148 by Strip
DEBUG: XInputExtension version is 2.3
DEBUG: Skipping virtual master devices and devices without axis valuators.
DEBUG: Skipping device 'Virtual core XTEST pointer' id=4, does not report Absolute events.
DEBUG: Skipping device 'PixArt USB Optical Mouse' id=10, does not report Absolute events.
DEBUG: Skipping device 'winpad Keyboard' id=12, does not report Absolute events.
Warning: multiple calibratable devices found, calibrating last one (eGalax Inc. USB TouchController Pen)
use --device to select another one.
DEBUG: Selected device: eGalax Inc. USB TouchController Pen
DEBUG: Not usbtouchscreen calibrator: Not a usbtouchscreen device
DEBUG: Read axes swap value of 0.
DEBUG: Read InvertX=0, InvertY=0.
Calibrating EVDEV driver for "eGalax Inc. USB TouchController Pen" id=14
current calibration values (from XInput): min_x=2108, max_x=2018 and min_y=2082, max_y=2022
DEBUG: Found that 'eGalax Inc. USB TouchController Pen' is a sysfs name.
DEBUG: Adding click 0 (X=697, Y=510)
DEBUG: Adding click 1 (X=332, Y=514)
DEBUG: Adding click 2 (X=696, Y=260)
DEBUG: Adding click 3 (X=340, Y=262)
Doing dynamic recalibration:
Setting calibration data: 2042, 2084, 2039, 2065
DEBUG: Successfully applied axis calibration.
--> Making the calibration permanent <--
Install the 'xinput' tool and copy the command(s) below in a script that starts with your X session
xinput set-int-prop "eGalax Inc. USB TouchController Pen" "Evdev Axis Calibration" 32 2042 2084 2039 2065
xinput set-int-prop "eGalax Inc. USB TouchController Pen" "Evdev Axes Swap" 8 0
08 Jan 2018 10:41 #104156 by rodw
Replied by rodw on topic 19" Touchscreen
If you are moving in the wrong direction, it is possible that the system thinks the monitor is oriented upside down.
Is there any options in your display setup to rotate the screen? Does that help?
08 Jan 2018 14:13 - 08 Jan 2018 14:15 #104161 by Strip
Do you mean to flip the whole physical unit or flip it in the software? If I flip the physical unit wont the display be upside down? I know many may laugh at that question, but I am a newby, please be patient. I did not find an option to rotate the screen in the monitor menu. If there is one on the pathpilot controller I do not know how to find it.
Last edit: 08 Jan 2018 14:15 by Strip.
08 Jan 2018 20:21 #104179 by Strip
I talked to tormach CS, they said they have seen this issue before and it was bad monitors. I am returning this one.
Time to create page: 0.231 seconds
