- Thank you received: 486
Fitting an encoder on a Tormach 1100
6 years 5 months ago #167748
by Clive S
5i25_t2_7i85s.bit.
About 2 years ago
Replied by Clive S on topic Fitting an encoder on a Tormach 1100
Peter you made me the bit file for a Tormach that I used a 7i85 on the second port. For the spindle encoder and 3 mpg'sPCW wrote: Not sure who made that bit file, do you have the PIN_xxxx.vhd source file?
Do you have a 7I85 or 7I85S?
5i25_t2_7i85s.bit.
About 2 years ago
6 years 5 months ago #167751
by Sparky3
Replied by Sparky3 on topic Fitting an encoder on a Tormach 1100
Oh wow. I did not even look at the original post date.
Sorry
Sorry
6 years 5 months ago - 6 years 5 months ago #167752
Replied by PCW on topic Fitting an encoder on a Tormach 1100
Yes, there is one for a 7I85S but I don't have anything for a 7i85
Last edit: 6 years 5 months ago by PCW.
6 years 5 months ago #167758
by Sparky3
It was for the 7i85S. I was just curious if you could do tormach .bit with the 7i85. IF not the 7i85s will be fine if you can put the serial module in it.
6 years 5 months ago #167788
by Sparky3
To answer your question. have neither yet. but if the 7i73 will work on pathpilot I would prefer to to get the 7i85 with the extra serial ports
The serial hook up was tested using a differential driver/receiver that was put together out of scraps laying around. It works on other bit files with serial hookups.
Thank you
Robert
Thank you
Robert
6 years 5 months ago #167802
Time to create page: 0.222 seconds
