- Thank you received: 11
Fitting an encoder to non Tormach mill (5i25)
- rafferty
- Topic Author
Read the "Fitting an encoder on a Tormach 1100" thread and realise Tormach's modified encoder just takes a pulse per rev input.
Had a play with "num_encoders=" parameter, (setting to 0, 1 , 2) under v1.9.13 and now under v2.1.3, results are the same.
num_encoders=0, as expected no encoder.
num_encoders=1, adds the pulse per rev encoder over the IO Pin 016
num_encoders=2, adds the pulse per rev encoder but also what looks like a 'real' index and 2 phase encoder on P2, the second DB25.
Does anyone know anything about this 2nd encoder? Is it available ?
- Clive S
- Thank you received: 486
net spindle-position hm2_5i25.0.encoder.00.position => motion.spindle-revs
net spindle-velocity hm2_5i25.0.encoder.00.velocity => motion.spindle-speed-in
net spindle-index-enable hm2_5i25.0.encoder.00.index-enable <=> motion.spindle-index-enable
setp hm2_5i25.0.encoder.00.scale -4000
With halmeter you will need to find the names of your (hm2_5125.0.encoder.00.position) it could be )01 etc. and the same for the other pins. You might also have to remove the - sign for the scale if it is counting the wrong way
- rafferty
- Topic Author
Is the code you suggest for that 7i85/5i25 custom bitfile configuration?
I would like to use just the 5i25 with the newly found "real" encoder if possible.
Will do some testing of the newly found encoder with your suggested code.
- Clive S
You will be able to use the high speed encoder on the second port . if you connect it up you should see the pins change state with the halmeter.
- Thank you received: 5334
even if the A,B lines are brought out.
If you dont have a Tormach machine, I would use a non-Tormach bitfile with standard encoders
- rafferty
- Topic Author
PCW wrote: I'm pretty sure Tormach 1 pin encoder (for RapidTurn) does not work as a standard encoder
Is it possible encoder 0 is Tormach pulse per rev, and encoder >0 is standard...?
PCW wrote: If you dont have a Tormach machine, I would use a non-Tormach bitfile with standard encoders
It's non Tormach but I'm committed to their DB25 P3 pinout because of the interface hardware I built which looks exactly like a Tormach to the 5i25, down to the watchdog.
- rafferty
- Topic Author
Initially just added 2 encoders to the 100-3 ini file and used ADMIN HALMETER to look at the 2nd encoder's pins while I pulled the A, B and Index pins high and low. This worked.
Connected my DIY optical sensor's A, B and Index outputs to the encoder inputs, added simple encoder initialisation code to postgui file and again used halmeter to look at the signals.
There's a velocity output signal that is at least roughly proportional to spindle RPM from 200 to 3000 RPM and the sign is correct with respect to direction (after I swapped the A and B phases of course). The velocity value jumps about a bit, around +/-10 %, signal looks pretty clean on a CRO.
Is this worth persisting with?
- Clive S
- rafferty
- Topic Author
Clive s wrote: Watching with interest. Did you try the code above in post #117328
Sorry, no, not today, it might be a bit early to risk that. I was reading up on encoders this afternoon.
I'm not really confident what I'm seeing as velocity is correct. I'll feed it a clean square wave tomorrow and see if that's stable, if yes the +/-10% variation has an external cause.
Your code is for G33 co-ordianted motion I recall.
At one stage I took some bits of the duality ini and hal files and had actual spindle RPM on the DRO, I'll have to dive in to the UI python again, see if I can work out what I did.
Ken
rafferty wrote: Is this worth persisting with?
It sounds like it. You just need to make that encoder (speed, position) go to the right pins in HAL.
