5i25 dpll timer-number syntax
  • rafferty
  • Topic Author
  • Premium Member
  • Premium Member
8 years 1 month ago #117985 by rafferty
5i25 dpll timer-number syntax was created by rafferty
The HOSTMOT2 man page gives the syntax for specifying the dpll timer number for encoders and stepgens as
(s32 r/w) hm2_XiXX.N.encoder.MM.timer−num (default: −1)
but the PathPilot hal files that mention a dpll omit the encoder and stepgen instance number, "MM". Also "timer-number" use is inconsistent with the man page "timer-num"
setp hm2_[HOSTMOT2](BOARD).0.encoder.timer-number [HOSTMOT2](DPLL_TIMER_NUMBER) setp hm2_[HOSTMOT2](BOARD).0.stepgen.timer-number [HOSTMOT2](DPLL_TIMER_NUMBER)
Is there some default instance numbering going on that I've missed or is the man page incorrect?
8 years 1 month ago #117986 by PCW
Replied by PCW on topic 5i25 dpll timer-number syntax
The "MM" i and timer-num token in the hostmot2 manual page are incorrect,
it should be:
hm2_XiXX.N.encoder.timer−number
(and same format for the stepgen, SSI, BISS, and Fanuc encoders interfaces)
The following user(s) said Thank You: rafferty
8 years 1 month ago #118047 by andypugh
Replied by andypugh on topic 5i25 dpll timer-number syntax
I have fixed the docs.
Time to create page: 0.044 seconds
