Pathpilot 2.14 - Z goes opposite
8 years 1 month ago #118272 by racedirector
Just upgraded to PP 2.14, all went well after copying all my files to the new dir.... that is until I fired up the machine.
X & Y respond to my direction keys as normal however now Z goes down with Pg-Up and up with Pg-Down. Nothing has changed in any of the files.
I am trying to figure out why and have both 2.0 and 2.14 files to compare, will report what I find.
Just a warning to anyone else who tries this, it may not work as you think...
Cheers
8 years 4 weeks ago #118339 by racedirector
So I spent time comparing the files in 2.14 with 2.0 to no avail. Thought it was the keyboard so tried another one and no change. Rebooted my machine into LCNC with Gmoccapy and the PgUp & PgDn keys work as expected.
I am going to look for anything outside PP that may have caused this, I am suspecting it has something to do with executing ADMIN TOUCHSCREEN on 2.0 that is no affecting 2.14.
Failing finding the cause I might just go back to standard LCNC with GMoccapy until that new GUI comes out, I really don;t have the time to fully get to the bottom of this if it is not simple.
8 years 4 weeks ago #118343 by sharmstr
What new GUI?
8 years 4 weeks ago #118344 by racedirector
The following user(s) said Thank You: sharmstr
8 years 4 weeks ago #118345 by andypugh
Is the problem _only_ with the jog keys? Does the Z axis move as-expected with MDI and homing?
Tormach machines are moving-spindle, is your machine moving table?
8 years 4 weeks ago #118350 by racedirector
Yes and yes
Problem is with PgUp and PgDn only.
3 axis gantry router, 2 X, 1 Y, 1 Z.
Everything worked with 2.0, crapped out with 2.14
Time to create page: 0.167 seconds
