Pathpilot 2.14 - Z goes opposite
8 years 4 weeks ago #118351 by andypugh
Sounds like a Pathpilot setting then.
Are you sure it is wrong? PgDn should make the Z numbers smaller. (regardless of machine layout)
8 years 4 weeks ago #118352 by racedirector
Definitely something in PP
PgDn has always lowered the Z towards the table, PgUp has always raised the Z. My Z home is at the top so all downward movement is negative.
8 years 4 weeks ago #118356 by andypugh
That's really strange. Even for a Tormach machine the current behaviour you report is wrong.
You might be able to fix it in keymapping...
askubuntu.com/questions/228050/is-there-...r-international-keyb
(Though this is just an idea, it might be a daft one)
8 years 4 weeks ago #118360 by sharmstr
The jogging code hasnt changed recently. If you want to try this, you can switch the direction in code. Check out lines 3748 to 3753 in tormach_mill_ui.py
elif kv == gtk.keysyms.Up: jog_axis = 1 jog_direction = 1 elif kv == gtk.keysyms.Up: jog_axis = 1 jog_direction = -1
8 years 4 weeks ago #118400 by racedirector
One last thing I am going to try, I'll relink tic to V2.0 and see what happens. If my keys work with that version (the original I was on) I will investigate 2.14 further, if not its back to standard LCNC......
8 years 4 weeks ago #118401 by racedirector
Definitely weird
Relinked tmc to 2.0, fired it up and hey presto my PgUp & PgDn keys work as expected.
Relinked back to 2.14, fired it up and they are backwards again.
Going to try the edit above and see what happens.
Time to create page: 0.174 seconds
