- Thank you received: 5334
Setting up lathe speed with 7i76 digital pot
7 years 10 months ago #123270
Replied by PCW on topic Setting up lathe speed with 7i76 digital pot
What are the values of:
hm2_5i25.0.7i76.0.0.spinena and hm2_5i25.0.7i76.0.0.spinout
when you have requested full spindle speed?
7 years 10 months ago #123274
by Stigoe
Replied by Stigoe on topic Setting up lathe speed with 7i76 digital pot
I changed the settings for .spinena back to how they were.
As long as spindle is On, .spinena is true.
I tried both in low and high gear (in PP) and the results are
Low: .spinout equals set RPM
High: Obviously my scale is not set correct, as my results are
RPM .spinout
200 145.3488
1000 726.7442
1800 1308.14
No change in actual RPM of the spindle in any of these tests.
Stig
RPM .spinout
200 145.3488
1000 726.7442
1800 1308.14
Stig
7 years 10 months ago #123275
If you only have 2.2V across the 7I76's digital potentiometer you wont get any output voltage. I suspect you will have to supply an external 10 or 12V power source for this to work since it appears that the motor controller cannot supply the couple mA that the 7I76's digital potentiometer requires. Beware that the potentiometer wiring on many low cost speed controls is _HOT_ = at line voltage potential so any external power supply
must be isolated (something like a wall wart may work)
7 years 10 months ago #123277
by Stigoe
So connect negative of the external psu to both speed controller (bottom of pot) and spindle- and positive to spindle+ ?
7 years 10 months ago - 7 years 10 months ago #123278
_Maybe_
Do you have any documentation on the drive?
Are you sure potentiometer+ from the drive is DC? (relative to potentiometer-)
The 7I76 (voltage output) potentiometer replacement is meant for DC voltage controlled drives,
not all inexpensive SCR drives work this way however
Last edit: 7 years 10 months ago by PCW.
7 years 10 months ago #123279
by Stigoe
No, but it is the same clone of a KBMM-225 (or something like that) as used on most of these Chinese benchtop mills and lathes.
I measured 5.5v DC across the original potmeter, so I'm fairly certain it is DC controlled. I can test if there are any AC there as well.
Time to create page: 0.254 seconds
