PathPilot keeps running out of room in the partition
21 Jul 2019 23:53 #140125 by smgvbest
thank you
I typed incorrectly though, I meant I don't recall the parms
swappiness is set via the VM setting in sysctl i believe.
22 Jul 2019 00:34 #140134 by Vmax549
operator@tormachpcnc:~$ DF
DF: command not found
operator@tormachpcnc:~$ du-s/
bash: du-s/: No such file or directory
operator@tormachpcnc:~$ df
Filesystem 1K-blocks Used Available Use% Mounted on
udev 4027204 4 4027200 1% /dev
tmpfs 809244 1408 807836 1% /run
/dev/sda3 14986712 9256652 4945680 66% /
none 4 0 4 0% /sys/fs/cgroup
none 5120 0 5120 0% /run/lock
none 4046204 80 4046124 1% /run/shm
none 102400 24 102376 1% /run/user
/dev/sda1 13509128 2129000 10670856 17% /boot
I only have the PathPilot install USB stick.
(;-) TP
22 Jul 2019 00:43 #140135 by smgvbest
you can get gparted live-cd from here
gparted.org/download.php
your root paritiion is
i take it you re-installed already?
if do before you do anything, try running gparted again and make sure you select /dev/sda3 to extend it.
if not try the live-cd and burn it to a cd, then boot from it and try to extend your /dev/sda3 that way.
oh, the du command is du <space> -s and since your operator
the commadn would be
sudo du -s /
to help out before you edit another file you might want to open s terminal and
sudo su -
to get a root session, keep it open. if you run out of space that session should remain working
you can troubleshoot from it
22 Jul 2019 12:42 #140171 by Vmax549
I tried Gpart again and THIS time it came up as a command line function. Last time it had a GUI function. No plans to play with a Com Line function.
Any idea on how to bring it up as a GUI ?? I used sudo gpart
(;-) TP
  • Todd Zuercher
  • Todd Zuercher's Avatar
  • Platinum Member
  • Platinum Member
22 Jul 2019 13:04 #140172 by Todd Zuercher
Replied by Todd Zuercher on topic PathPilot keeps running out of room in the partition
Gpart is a command line tool (for recovering damaged disk partitions), Gparted is a gui (Gnome) partitioning tool.
22 Jul 2019 14:05 #140175 by Vmax549
AHHHHH thanks Todd
(;-) TP
22 Jul 2019 14:22 #140177 by Vmax549
OK good news (;-) for a change. What ever teh updates did the partition grew from using 32gb to using all available space on teh drive. .
We are now good to go.
(;-) TP
Time to create page: 0.127 seconds
