4th axis toolpath display
- Vmax549
- Thank you received: 28
29 Jul 2019 00:21 #140854
by Vmax549
Replied by Vmax549 on topic 4th axis toolpath display
I only know this is how it has worked since I loaded PathPilot.
Yes I changed teh AXYZ to XYZA and I have restarted pathPilot several times. It is displaying the correct toolpath image NOW when you enable teh 4th axis display (PP option) But it only rotates teh cone.
TP
- Vmax549
29 Jul 2019 00:34 #140855
by Vmax549
In this section of teh UI. Why would it state NONE
if enable_a:
self.enable_fourth_axis_toolpath_display(None)
def init_fourth_axis(self):
enable_a = T
if self.ui.redis.hexists('machine_prefs', 'enable_fourth_axis_toolpath'):
enable_a = self.ui.redis.hget('machine_prefs', 'enable_fourth_axis_toolpath') == 'True'
if enable_a:
else:
self.disable_fourth_axis_toolpath_display(None)
if enable_a:
enable_a = T
if enable_a:
else:
- smgvbest
- Thank you received: 51
29 Jul 2019 00:45 #140856
by smgvbest
Replied by smgvbest on topic 4th axis toolpath display
"The None keyword is used to define a null value, or no value at all."
So because self is inferred by the call and widget is not used in the call at all, but since the call expects something None is passed.
so since self is inferred the call is effectively
self.enable_fourth_axis_toolpath_display()
- Vmax549
29 Jul 2019 01:18 #140857
by Vmax549
OK that makes sense.
Question seeing how you run LinuxCNC does IT display teh 4th axis tool pathing correctly. Rotating teh toolpath and not teh tooltip icon .
Thanks, (
TP
Thanks, (
- smgvbest
29 Jul 2019 01:55 #140858
by smgvbest
If you're asking me, I don't run LinuxCNC, I do reference it for trying to find how things normally work but I run PP for a Lathe.
- pl7i92
- Thank you received: 358
29 Jul 2019 06:56 - 29 Jul 2019 07:07 #140864
by pl7i92
Replied by pl7i92 on topic 4th axis toolpath display
you know that the Y and Z Join limit switch position in the INI file needs to change
so it is the mesurment between your Switch and the CENTER YZ of the Rotory table
the pathpilot does not display out of box g-code
i atatched the venusmilo file around A
Last edit: 29 Jul 2019 07:07 by pl7i92. Reason: file
- Vmax549
29 Jul 2019 13:13 #140883
by Vmax549
I tried that file and it displays but does not run teh 4th axis toolpathing correctly. I have come to teh conclusion that PathPilot is not capable of a proper 4th axis toolpathing.
OH Well , It is what it is. (
TP
Time to create page: 0.123 seconds
