Testing Encoder with Halmeter
7 years 3 months ago #140528 by Vmax549
I am setting up a spindle encoder in PathPilot with a 7i80. I have it hooked up and can see the encoder count up and down correctly in halmeter but I cannot see the index signal.
Halmeter says the index is NOT enabled. I have the following in the HAL file
net spindle-position hm2_7i80.0.encoder.00.position => motion.spindle-revs
net spindle-velocity hm2_7i80.0.encoder.00.velocity => motion.spindle-speed-in
net spindle-index-enable hm2_7i80.0.encoder.00.index-enable <=> motion.spindle-index-enable
setp hm2_7i80.0.encoder.00.scale 400
Is there anything else I have to setup to enable the index signal ??
(;-) TP
7 years 3 months ago #140531 by PCW
Replied by PCW on topic Testing Encoder with Halmeter
To check the index, monitor spindle-index-enable with halmeter and then:
halcmd sets spindle-index-enable
(spindle-index-enable should be true)
rotate the spindle by hand
(spindle-index-enable should go false at the index location)
7 years 3 months ago - 7 years 3 months ago #140532 by Vmax549
I folow you up to
Is this something I need to input
(;-) TP
Last edit: 7 years 3 months ago by Vmax549.
7 years 3 months ago #140533 by Vmax549
OK I found teh problem it works now.
Thanks (;-) TP
7 years 3 months ago #140536 by PCW
Vmax549 wrote: I folow you up to
(;-) TP
Yes, you do this from a terminal window when LinuxCNC/PathPilot is running
You can also do this via halshow in the GUI but its a bit more awkward
7 years 3 months ago #140543 by Vmax549
HUM that is hard to in PathPilot as when you have Halmeter up and do anything in PathPilot it pushes teh Halmeter stuff BEHIND teh main screen where you cannot see it.
(;-) TP
Time to create page: 0.119 seconds
