Joint 0 following error
06 Sep 2019 07:53 #144339 by Stigoe
Joint 0 following error was created by Stigoe
Hi.
I'm still working on my lathe conversion to use PP and one of my problems is when I try to jog the X-axis with the keyboard arrow keys. Every time I press and hold down the arrow key, it e-stops with the "joint 0 following error" after 13.113mm and multiples (I'm working in metric, but PP settings are in inch).
From my searching, it looks like it's mostly a problem with servos, but I'm using steppers, and it's mostly caused by ferror and min_ferror being too low. I've tried to increase them, but I need to increase ferror very high before it will stop erroring out. I don't have any problems with Z-axis, even if it has the same settings as X-axis. Anyone have any ideas on how to fix this properly?
Attached is my tormach_lathe_base-ini
Br,
Stig
06 Sep 2019 12:20 #144372 by bevins
Replied by bevins on topic Joint 0 following error
Post your hal file.
06 Sep 2019 13:51 #144380 by Stigoe
Replied by Stigoe on topic Joint 0 following error
Here are the hal-files. They are a work in progress, so they are a bit of a mess now and not cleaned up yet. I'm also running v2.02, so not the latest version yet. I want to get this up and running properly before I upgrade and move over my changes.
06 Sep 2019 15:46 #144393 by PCW
Replied by PCW on topic Joint 0 following error
You need to post the ini file also so the basic motion constants can be checked
  • Moderator
  • Moderator
06 Sep 2019 15:57 #144396 by tommylight
Replied by tommylight on topic Joint 0 following error
Ini is attached to the first post.
06 Sep 2019 17:00 #144400 by PCW
Sorry Missed it
I don't see anything obviously wrong with the hal/ini files
If this were LinuxCNC I would ask for a halscope plot of the following error...
I would almost suspect a hardware problem with the PC or 5I25 card
06 Sep 2019 18:19 #144403 by smgvbest
Replied by smgvbest on topic Joint 0 following error
You should be able in v2 to do a ADMIN HALSCOPE from mdi
06 Sep 2019 18:42 #144406 by Stigoe
I take it you wanted to see axis.0.f-error? I could start halscope, but I didn't manage to get any results. I tried Run mode both Normal and Single and Trigger Normal and Auto. Anything special I need to set up?
It could possibly be something with the PC. It has problems doing POST. It seems to reboot a few times before it complains about no boot device. After doing a Ctrl-Alt-Del, it will boot normally. I don't know if this is caused by the PC, HDD or maybe the 5I25 card. I can try to move the HDD over to a different PC and try that.
06 Sep 2019 19:08 #144410 by PCW
Yes, axis.0.f-error would be good.
Note that after you select a pin to plot with halscope, you need to
change the run mode to stop and then select the desired run mode
(I would use "roll" mode to start with)
06 Sep 2019 19:26 #144413 by Stigoe
I still don't get any results.
Time to create page: 0.212 seconds
