Upgrade to PP 2.24
- Robi63
23 Sep 2019 21:44 #146006
by Robi63
Upgrade to PP 2.24 was created by Robi63
Hello,
I upgraded my lathe to Pathpilot 2.24, when I start the spindle does not start.
Gives me this error: " RPM must be between 0 and 0 in present spindle config" .
Where is the spindle speed configured?
On Pathpilot 2.16 I didn't have this problem.
Thanks for every suggestion
- NewToRouting
27 Sep 2019 13:43 - 27 Sep 2019 17:15 #146384
by NewToRouting
Replied by NewToRouting on topic Upgrade to PP 2.24
Sorry I can't answer that. But would you mind pointing me to where I could get a copy. I'm not sure what I should buy on their web site?
Last edit: 27 Sep 2019 17:15 by NewToRouting.
- smgvbest
- Thank you received: 51
19 Oct 2019 13:17 #148319
by smgvbest
Replied by smgvbest on topic Upgrade to PP 2.24
can you post of screen capture of the screen while its displaying the error?
- smgvbest
19 Oct 2019 13:18 #148320
by smgvbest
go here and purchase
www.tormach.com/store/index.php?app=ecom&ns=prodshow&ref=38249
- Robi63
19 Oct 2019 15:07 #148333
by Robi63
Replied by Robi63 on topic Upgrade to PP 2.24
I solved
It was due to [SPINDLE_9] in the .ini file and hal
I solved by correcting in [SPINDLE]
- NewToRouting
19 Oct 2019 16:29 #148342
by NewToRouting
Thanks for the reply I really appreciate it. Does this upgrade look for a previous version of PP to proceed or can I do a clean install for the USB?
Thanks Again - ed
Thanks Again - ed
- smgvbest
19 Oct 2019 16:43 #148344
by smgvbest
I used it for a clean install.
Just be sure your bios is set to uefi boot from the usb stick
- NewToRouting
21 Oct 2019 20:54 #148490
by NewToRouting
Thanks again .I really do appreciate your help.
- belli
09 Nov 2019 12:53 #149980
by belli
Replied by belli on topic Upgrade to PP 2.24
Hey NTR,
I just did a fresh install of PP v2 and it has a selection for every 1100 down to serial number 1. I think you can just install PPv2 without any troubles. I didn't install any of the older versions coz my BOB is new.
- NewToRouting
12 Nov 2019 23:20 #150259
by NewToRouting
Thanks for your reply.
Time to create page: 0.117 seconds
