Pathpilot V2 and 7i96 MESA Card
6 years 10 months ago #152121 by smgvbest
could you not take the hostmot driver from 2.8/9 and backport to 2.8-pre1.
6 years 10 months ago #152131 by PCW
Replied by PCW on topic Pathpilot V2 and 7i96 MESA Card
That should work though you would lose compatibility with Tormach Ethernet controllers
6 years 10 months ago #152132 by davidimurray
PCW wrote: You could use a 7I76E (more expensive but more I/O)
I assume the 7i76e will work ok with pathpilot? As i'm building a lathe, IO requirements aren't great hence the thought of using a 7i96 to save a nit of money
6 years 10 months ago #152136 by davidimurray
If you're feeling brave....... i've complied a version of 2.8.0-pre1 on a virtual machine. I've just copied the HM2 files from the rtlib folder and attached them below.
The following user(s) said Thank You: Dorro1971
6 years 10 months ago #152156 by Vmax549
One thing to keep in mind is that PP uses routines and outside functions that are not in LinuxCNC. Things such as redis PP relies on a lot to transfer data back and forth between teh GUI and teh Gcode side.
My mission is to stay inside of teh PP functions . That way I get updates when PP updates and new features when PP updates and Tormach does all teh hard work.
(;-) TP
6 years 9 months ago #155673 by perra_e
I'm about to retrofit a lathe and I plan to use PathPilot V2. For this i was hoping to use a 7i92 + 7i76 but the 7i92 is out of stock both at eusurplus and mesa store..
Has any one succeded to run PathPilot 2 with 7i80db + 7i76?
I have a 7i80db in my mill so it is tempting to use ut in the lathe as well.
--Per
Time to create page: 0.284 seconds
