Pathpilot V2 and 7i96 MESA Card
6 years 11 months ago #150638 by davidimurray
Now that PP V2 has support for the 7i92 - I was wondering if anyone had tried a 7i96 card. Building a new lathe at the moment and thinking that the 7i96 would be a good low cost option.
Cheers
Dave
6 years 11 months ago #150643 by Vmax549
HI Dave, I have been setting up the 7i80s with PPand they have been extremely well behaved. The 7i80 is basically the same thing only with 4 full ports of I/O.
I would expect teh same behavior from a 7i96.
Very happy here anyways, (;-) TP
6 years 11 months ago - 6 years 11 months ago #150655 by PCW
Replied by PCW on topic Pathpilot V2 and 7i96 MESA Card
My guess is that a 7I96 would not work with PathPilot because the 7I96 was introduced after Pathpilot was forked from LinuxCNC. It should be possible to merge Pathpilots driver changes with the current LinuxCNC version (or just replace it with the current LinuxCNC version if you don't need ECM board support) but that may be more than most users want to do
Last edit: 6 years 11 months ago by PCW.
6 years 11 months ago #150658 by Vmax549
HI PCW, please explain more why the 7i96 does not work with PathPilot . It would seem IF the 7i80 worked then the 7i96 should ?? Of course you do have to do a small bit of changing the Hal files to match the new cards I/O.
(;-) TP
6 years 11 months ago - 6 years 11 months ago #150659 by PCW
The 7I96 has a new firmware module for the isolated outputs and that would likely not be supported by Pathpilot. I am not a PathPilot expert but AFAIK they have changed/forked the hm2 driver and are not up-to-date with the latest LinuxCNCs changes
(and the 7I80 was supported before the fork)
6 years 11 months ago #150662 by Vmax549
AH ok now I understand . IS there a card like teh 7i96 with BOB that is supported ??
(;-) TP
Time to create page: 0.353 seconds
