Using I/O pins on teh mesa card
- Vmax549
- Thank you received: 28
19 Nov 2019 16:48 #150685
by Vmax549
Using I/O pins on teh mesa card was created by Vmax549
How do you setup teh Mesa I/O pins to be used by PathPilot in calls like M65/M66. It calls for a pin number. So how do you associate teh M65 pin # to teh Mesa Pin # ?
I hope I asked that correctly. I think I see how it is done in the HAL but not exactly sure it is what I think it is.
TP
- Thank you received: 5337
19 Nov 2019 17:07 #150688
Replied by PCW on topic Using I/O pins on teh mesa card
You have to connect Linuxcnc/PathPilots digital-out pins to the appropriate physical pin,
see:
linuxcnc.org/docs/html/gcode/m-code.html#mcode:m62-m65
Something like this on a 7I80:
First setup the hardware pin
setp hm2_7i80.0.gpio.023.is_output true # set GPIO23 into output mode
and possibly
setp hm2_7i80.0.gpio.023.invert_output true # invert output
then connectPathPilots digital output to the hardware pin
net some_signal_name motion.digital-out-00 ==> hm2_7i80.0.gpio.023.out
see:
and possibly
- Vmax549
19 Nov 2019 17:37 #150694
by Vmax549
Replied by Vmax549 on topic Using I/O pins on teh mesa card
That was what I was seeing in the hal file just wanted to make SURE before I murdered the script.
Thanks for teh Time, (
TP
- smgvbest
- Thank you received: 51
19 Nov 2019 17:47 #150696
by smgvbest
Replied by smgvbest on topic Using I/O pins on teh mesa card
In PP the M65 are mapped for the USBIO card. you can however change this to map to real pins in the HAL file.
look in the postgui hal file for
# USBIO
net usbio-enabled tormach.usbio-enabled => usbio.enabled
net dig-out-0 tormach.usbio-output-0
net dig-out-1 tormach.usbio-output-1
net dig-out-2 tormach.usbio-output-2
net dig-out-3 tormach.usbio-output-3
net dig-in-0 tormach.usbio-input-0
net dig-in-1 tormach.usbio-input-1
net dig-in-2 tormach.usbio-input-2
net dig-in-3 tormach.usbio-input-3
change as you need for you pins
# USBIO
- Vmax549
19 Nov 2019 17:55 #150698
by Vmax549
Yes that is what I was looking to do . In the PP hal there are 16 ins and 16 outs for teh USBI/O. I was going to redirect them to mesa pins.
Easy peazy I hope , (
TP
- Thank you received: 4657
24 Nov 2019 14:26 #151135
Was it?
Replied by andypugh on topic Using I/O pins on teh mesa card
Easy peazy I hope ,
Was it?
- Vmax549
24 Nov 2019 14:49 #151138
by Vmax549
Actually yes it was
. It is a lot of typing even with cut and paste but doable.
The next hard project will be trying to integrate a tool changer into teh PP way of doing things. THAT is going to be a tuffy . IF one could buy their ATC control card it might be very easy BUT they said sorry no deal . I even tried teh MANF of teh ATC and they also said no deal. The actual working of teh add on ATC is VERY simple just some inouts and outputs and waits and spin teh carrosel to position and some more ouputs and inouts and waits BUT trying to unwind how PP does it is a tuff cookie.
I might try and unwind the logic of the ATC card and use an Adurino to run it BUT that is another story in itself and I am not a programmer.
TP
- smgvbest
24 Nov 2019 14:54 #151140
by smgvbest
Their tool changer card is basically their usbio card with slightly modified commands
I’ve got a hdr for the various cards I threw together then you can use the teensyio mentioned in the forum to implement
- Vmax549
24 Nov 2019 14:59 #151142
by Vmax549
OK what is an hdr ?? What appears to be the firmware for teh ATC card is in PP folder. IT appearantly updates when needed
The ATC cards has to be able to do motor control as well as I/O
IF you have more info on teh cards I am all ears (
The following user(s) said Thank You: Todd Zuercher
- Vmax549
24 Nov 2019 15:05 #151144
by Vmax549
The ATC I am working to interface needs 10 outputs and 12 inputs and 1 channel of S/D to run a servo to spin the carrosel into position.
It has been run in Mach3 and UCCNC so it is not really rocket science. The real trick will be to integrate it into teh PP tool change process without a lot of changes to teh PP code. The PP code can handle between 8 tool pockets up to 16 tool pockets for the MX and a BT30 spindle with spindle orientation.
TP
Time to create page: 0.204 seconds
