Pathpilot MiniPC
6 years 10 months ago #153014
I'll try and remember. It might be a while as the machine is at work and I'm off for Christmas.
Replied by rodw on topic Pathpilot MiniPC
smgvbest wrote: @rodw Would you mind putting the contents of your /boot/grub/grub.conf here so I can see it. I'm wondering if it has NOMODESET or if its using something else to over come the issue I'm having.
6 years 4 months ago #170075
by gcardinal
Replied by gcardinal on topic Pathpilot MiniPC
I also ended up getting this mini PC GB-BXBT-1900 (MZBAYAB-00). As a starting point I looked into
this post
for BIOS settings. I also removed WiFi card from the PC. Did all the tests without network connection.
Running on stock linuxcnc-stretch-uspace-amd64.iso from 2018-10-27 17:57
Here is my BIOS dump:
Results are kinda not impressive:
Servo: 210028ns
Base: 170048ns
With 6x glxgears and with various apps running
BIOS Version: F9
CPU SMART FAN Function: Enabled
CPU FAN Fail Detect: Disabled
Wake system from S5: Disabled
Intel Virtualization: Disabled
EIST: Disabled
CPU C state Report: Disabled
SATA Mode: AHCI Mode
CSM Support: Enabled
LAN PXE OpROM: Disabled
DVMT Pre-Allocated: 64M
Onboard Audio: Enabled
Onboard LAN: Enabled
XHCI Hand Off: Enabled
OS Selection: Windows 7
ERP Support: Enabled
Restore AC Power Loss: Power On
Secure Boot: Disabled
Secure Boot Mode: Standard
Fast Boot: Disabled
Servo: 210028ns
Base: 170048ns
6 years 4 months ago #170080
do your testing without the base thread as with Mesa ethernet hardware (which I assume you are using) you do not need a base thread.
210028 is still OK for Mesa Ethernet. Mine is around 120000
6 years 4 months ago - 6 years 4 months ago #170091
by gcardinal
Last edit: 6 years 4 months ago by gcardinal.
6 years 4 months ago #170094
by gcardinal
Time to create page: 0.243 seconds
