PP din socket for tool setter
  • Clive S
  • Topic Author
  • Platinum Member
  • Platinum Member
6 years 5 months ago #166618 by Clive S
PP din socket for tool setter was created by Clive S
PP din socket for tool setter connections
I have a tool setter non Tormach but looks the same mine does not have a led only to switches one for the tool trip and the other NC for the over travel fault.
I am looking for the connections to this DIN socket for the two switches. I believe pin 1 is 5v dc - pin 4 is common - pin 2 not used - pin5 input - pin 3 is 12v dc
6 years 5 months ago #166620 by smgvbest
Replied by smgvbest on topic PP din socket for tool setter
Check out Tormachs site for thier probes.
here's the direct link to the page and doc
tormach.com/passive-probe-kit-32309.html
pdf here
tormach.com/media/asset/t/d/td10088_pass...be_install_0515a.pdf
last page has the pin-out
this is my opinion
grab the Tormach doc on anything you're trying to implement. they do a decent job of documenting things
6 years 5 months ago #166623 by belli
Replied by belli on topic PP din socket for tool setter
PIN1 = 12V
PIN2 = 5V
PIN4 = GND
PIN5 = Probe Input
  • Clive S
  • Topic Author
  • Platinum Member
  • Platinum Member
6 years 5 months ago #166628 by Clive S
Replied by Clive S on topic PP din socket for tool setter
belli wrote: PIN1 = 12V
PIN2 = 5V
PIN4 = GND
PIN5 = Probe Input
Yes that is looking at the back
  • Clive S
  • Topic Author
  • Platinum Member
  • Platinum Member
6 years 5 months ago - 6 years 5 months ago #166629 by Clive S
double post
Last edit: 6 years 5 months ago by Clive S.
  • Clive S
  • Topic Author
  • Platinum Member
  • Platinum Member
6 years 5 months ago #166630 by Clive S
smgvbest wrote: Check out Tormachs site for thier probes.
pdf here
this is my opinion
Thanks. I had not seen that PDF
but I had the pin outs from the manual. But the tool setter I have has another switch lower down NC contacts I would like to put this switch in the estop chain or some other way of stopping the machine if the first one fails
any suggestions?
6 years 5 months ago #166649 by snowgoer540
Replied by snowgoer540 on topic PP din socket for tool setter
pdf here
this is my opinion
any suggestions?
I used the unused pin on Tormach’s side as follows:
One side of NC switch over travel goes to 12+.
The other side goes to the unused pin.
Inside the cabinet I used a solid state relay, took the wire from the unused pin to one side of the SSR, the other side of the SSR to the ground pin on the DIN. On the switched side of the SSR, I wired it in series with the E-stop on the cabinet. That way if it over travels the relay goes open and the machine e-stops.
  • Clive S
  • Topic Author
  • Platinum Member
  • Platinum Member
6 years 5 months ago #166652 by Clive S
Yes I was thinking along those lines but I did nor want to keep the din plug in all the time. I suppose I could put a dummy plug in or a switch on the panel across the relay contacts.
Do you know what the voltage on the e-stop chain is and is it AC or DC
6 years 5 months ago - 6 years 5 months ago #166667 by snowgoer540
Clive S wrote: Yes I was thinking along those lines but I did nor want to keep the din plug in all the time. I suppose I could put a dummy plug in or a switch on the panel across the relay contacts.
I planned on a dummy plug as well.
It’s 110v in my machine as I recall.
Last edit: 6 years 5 months ago by snowgoer540.
Time to create page: 0.070 seconds
