Coolant ON OFF / M8 M9 using Mesa 7i76e for non-Tormach machine
6 years 5 months ago #167259 by DanieGouws
Hallo Everybody,
I'm sure this is a very basic question but my very limited linuxcnc knowledge is a great disadvantage.
I have Pathpilot V2.0 controlling a Denford lathe using a Mesa 7i76e card and most functions are running except the coolant ON/OFF from the interface or using a M8 / M9 command. I would appreciate it very much if someone can help me with the hardware setup and .HAL file, currently my Emergency STOP and limit switches are wired to 7 and 6 of TB6, respectively. I find it very difficult to understanding the mapping of the physical pins from using the PnCConf Wizard to the .HAL file.
Thank you very much, Danie
6 years 5 months ago #167260 by JohnnyCNC
I'm using Axis and this is how my coolant signals are connected. I am using a 5i25+7i76.
# ---coolant signals---
net coolant-mist <= iocontrol.0.coolant-mist
net coolant-mist => hm2_5i25.0.7i76.0.0.output-00
The iocontrol.0.coolant-mist is connected to the signal coolant-mist and then the signal coolant-mist is connected to the physical pin hm2_5i25.0.7i76.0.0.output-00. The "<=" symbols are just for the human reading the file and is not an actual operator so you can think of the signal path like this iocontrol.0.coolant-mist => coolant-mist => hm2_5i25.0.7i76.0.0.output-00
6 years 5 months ago #167716 by DanieGouws
Thank you very much for the feedback, solution and explanation. After some troubles I found placing the following code in the HAL file:
net coolant-flood <= iocontrol.0.coolant-flood
net coolant-flood => hm2_7i76e.0.7i76.0.0.output-00
enabled me to trigger output 0 on Pin 17 of TB6 using M8 and M9.
Pushing the Coolant button on the PathPilot interface still has no effect - I assume some additional mapping is still required.
Time to create page: 0.218 seconds
