M66 doesn't work
6 years 3 months ago - 6 years 3 months ago #174938 by Aciera
Replied by Aciera on topic M66 doesn't work
In the picture of your HAL setup there is no setup for motion.digital-in-02 you have two entries for motion.digital-in-03.
You are waiting for motion.digital-in-02 but have not set up a signal.
Last edit: 6 years 3 months ago by Aciera.
The following user(s) said Thank You: Duongtantai8624
6 years 3 months ago #174939 by andypugh
Replied by andypugh on topic M66 doesn't work
Duongtantai8624 wrote: Im stuck with this more than 2 days, i tried all M66 example i can find but it's still not work
when the code run to M66 line the cycle is stop
There is a problem in your HAL configuration, it looks like a copy-paste error.
in0
in1
in3
in3
You have set up input 3 twice, and input 2 not at all.
6 years 3 months ago - 6 years 3 months ago #174940 by Duongtantai8624
Replied by Duongtantai8624 on topic M66 doesn't work
Sorry i just post wrong picture :( :( :(
Im trying everything i could, change port ,change mode etc ...
Last edit: 6 years 3 months ago by Duongtantai8624.
6 years 3 months ago #174942 by andypugh
If you use the halmeter, can you watch the dig-in-2 signal and the motion.digital-in-02 signal to be sure that they are triggering as-expected?
Which Mesa board are you using? It isn't that usual to use the bare gpio pins on most of them now.
Are you sure that gpio-032 is not being claimed as an output pin by a step-generator or similar?
If you can tell us the board, firmware and loadrt_hm2 lines from the HAL file we might be able to help more.
6 years 3 months ago #174945 by Duongtantai8624
My setup is a little bit weird cause im in third wolrd country so i have to stick with third world solution
This is pci e motion control card
This is linuxcnc bob
I use mach 3 board + relay board for io pin
Here's the loadrt line, but it no hm2 ::pinch:
I dont know how to open halmeter, i will figure out how to do it later but this is io port list show in operator_login
6 years 3 months ago #174948 by andypugh
That seems to be a clone of a 5i25. So there is no real guarantee that the dmesg output that tells you that GPIO 32 is on DB25 pin 12 is correct.
Can you use Halshow with PathPilot? That would let you check which physical input (if any) triggers when you toggle the physical input.
Time to create page: 0.358 seconds
