- Thank you received: 4
M66 doesn't work
- Duongtantai8624
- Topic Author
6 years 3 months ago - 6 years 3 months ago #174898
by Duongtantai8624
M66 doesn't work was created by Duongtantai8624
Hi all
Im new to linuxcnc and pathpilot is my first try, i got everything to work accept M66
I tried this code to check the spindle orientation, the code will run again if orientation signal is false
My input signal in status tab still function, i checked it's work fine
This is my hal file
Im stuck with this more than 2 days, i tried all M66 example i can find but it's still not work
when the code run to M66 line the cycle is stop
Please help me what i did wrong ?
This is my hal file
Last edit: 6 years 3 months ago by Duongtantai8624.
- Duongtantai8624
- Topic Author
6 years 3 months ago - 6 years 3 months ago #174899
by Duongtantai8624
Replied by Duongtantai8624 on topic M66 doesn't work
thanks for reading
6 years 3 months ago #174907
Replied by cmorley on topic M66 doesn't work
Are you sure pilotpath support M66?. Pilotpath doesn't use the exact same code as linuxcnc so it's hard for the linuxcnc project developers to comment.
Hopefully a pilotpath user can help.
- Duongtantai8624
- Topic Author
6 years 3 months ago - 6 years 3 months ago #174915
by Duongtantai8624
im not sure pathpilot support M66 cause i've changed to linuxcnc from mach3 for 3 months, i use old version pathpilot v2.0.0
i tried M66 example on tormach manual so i guess it does support M66
tormach.com/wait-on-input-m66
thanks for your reply cmorley
6 years 3 months ago #174924
Replied by rodw on topic M66 doesn't work
So what is it that makes your digital input go high? You might be waiting for something that never happens?
The following user(s) said Thank You: Duongtantai8624
- Duongtantai8624
- Topic Author
6 years 3 months ago #174937
by Duongtantai8624
I use mach 3 board for usb io port, when the port go low the usbio inputs light's up
I realy dont understand your question but do you mean even if usbio inputs light's up, M66 still may not work ?
Time to create page: 0.173 seconds
