Need help with Parallel Port Setup. (ESTOP issue)
- shadab
- Thank you received: 4
14 Sep 2020 14:16 #182084
by shadab
Need help with Parallel Port Setup. (ESTOP issue) was created by shadab
We are working to retrofit a sherline VMC with linuxcnc/Pathpilot. We are using a 4 AXIS TB6560 Driver Board to control the machine.
I was following the tutorials provided by Sarah on how to configure the Pathpilot configs to work with a parallel port. I was able to make it work somewhat because whenever I am trying to jog X or Y axis using the keyboard, the machine will jog a bit and then I'm getting an ESTOP error. I suspect it is because of lack of debouncing the pin as we have directly connected pin 13 of PP to ground via a switch.
I have attached the image of the error for the reference. TB6560 board has 4 inputs for limit switches out of which we decided to use 3 for limit switches and 1 as an external ESTOP which is connected to parallel port pin 13. Can someone take a quick glance at our hal/ini files to see whether the estop input pin config is correct or not.
Also is there a way to bypass this pathpilot ext-estop? We don't want an external estop to PP we only want to use the software estop in the PP gui.
Thanks,
Shadab
Thanks,
Shadab
- shadab
14 Sep 2020 14:22 - 14 Sep 2020 14:24 #182087
by shadab
Replied by shadab on topic Need help with Parallel Port Setup. (ESTOP issue)
Was not able to attach image so adding an external link: imgur.com/a/LWoZ1rm
Last edit: 14 Sep 2020 14:24 by shadab.
- smgvbest
- Thank you received: 51
15 Sep 2020 01:45 - 15 Sep 2020 01:45 #182170
by smgvbest
Replied by smgvbest on topic Need help with Parallel Port Setup. (ESTOP issue)
you're outputing the ESTOP not inputing it
setp parport.0.pin-01-out-invert 1
net estop-out => parport.0.pin-01-out
you need this on a input pin
Last edit: 15 Sep 2020 01:45 by smgvbest.
- shadab
15 Sep 2020 06:48 #182188
by shadab
I thought estop-out was supposed to be an output estop signal to the driver board's EN pin. As you can see from the parallel port pin configuration for the stepper driver board's first pin is EN pin for all of the axis drives.
Parallel port pin 10,11,12 and 13 are inputs while rest all are outputs(from the perspective of the computer). Please correct me if I'm wrong, my assumption, from reading the original tutorial's HAL/ini files is that estop-out is output signal from LCNC to driver and estop-ext is external estop input from an external E-switch to LCNC.
Also can this be an issue of debouncing, I've read in some other forum posts and people seem to have this issue. I can jog the x and y axis for aboout 30 seconds before the ESTOP occurs. Is it possible to bypass this estop-ext? Is it something PathPilot can work without?
Thanks,
Shadab
Attachment not found
Thanks,
Shadab
- shadab
15 Sep 2020 06:51 #182189
by shadab
I'm not able to view uploaded images for some reason, here's a link to images I was referring above imgur.com/a/ZBjY2GJ
- Thank you received: 2176
15 Sep 2020 08:53 - 15 Sep 2020 09:09 #182193
Replied by Aciera on topic Need help with Parallel Port Setup. (ESTOP issue)
What I see you have only connected parport.0.pin-13-in-not to a signal but not to any input pin? So it should not have any effect at all.
mill_pp.hal:
net estop-out => iocontrol.0.emc-enable-in
postgui_custom_pp.hal
[edit]
Try
net emc-enable <= parport.0.pin-13-in-not =>iocontrol.0.emc-enable-in
net estop-out <= iocontrol.0.user-enable-out => parport.0.pin-01-out
and comment out the others
PS I can't see any of your images. Have you attached png?
[edit 2]
You can run LinuxCNC without external ESTOP. However for safety reasons it is highly recommended to use an external emergenca button.
mill_pp.hal:
Warning: Spoiler!
Warning: Spoiler!
net estop-ext <= parport.0.pin-13-in-not
[edit]
Try
[edit 2]
Last edit: 15 Sep 2020 09:09 by Aciera.
The following user(s) said Thank You: shadab
- shadab
15 Sep 2020 11:27 #182209
by shadab
Thanks for the suggestion I tried to implement it. Disable the following lines:
I'm still getting the same error. If I disable all the estop lines I'm not getting any error and I'm able to run continuously. I'll check with my hardware team if there are any issues in the connection.
net estop-ext <= parport.0.pin-13-in-notI'm still getting the same error. If I disable all the estop lines I'm not getting any error and I'm able to run continuously. I'll check with my hardware team if there are any issues in the connection.
15 Sep 2020 12:47 - 15 Sep 2020 12:49 #182227
Not sure how you're able to get out of estop if you have all lines with iocontrol.0.emc−enable−in commented out? That needs to be active to get the gui out of estop.
Maybe attach the current config files.
[edit]
And have a look at parport.0.pin-13-in-not with the "hal-show" monitor to check if that is actually doing what it should.
[edit]
Last edit: 15 Sep 2020 12:49 by Aciera.
- shadab
15 Sep 2020 14:44 #182238
by shadab
In my recent post i forgot to mention only these two lines are active rest all are commented.. I will post the latest configs tomorrow asap.
Thanks,
Shadab
Thanks,
Shadab
- shadab
16 Sep 2020 06:54 #182388
by shadab
Hi David,
I have attached the files here. I'm able to home all three axis correctly and also the limit switches are working as expected.
Time to create page: 0.210 seconds
