PathPilot MegaMod
- gerritv
- Thank you received: 16
14 Nov 2020 19:45 - 14 Nov 2020 20:39 #189420
by gerritv
Replied by gerritv on topic PathPilot MegaMod
That is excellent work and result. Rotating the screen is a bril move.
How will you manage PathPilot updates? Diff the files and patch?
My machine is running Pathpilot 2.5, but not ready for real work just yet. Rolling stand, electrics panel, probe and ets still to be done. But it cuts al and steel so very happy so far. Presently trying to resurrect a Renishaw TP2 probe. I look forward to enhancing my installation based on your approach.
gerrit
gerrit
Last edit: 14 Nov 2020 20:39 by gerritv. Reason: clarification
- snowgoer540
- Thank you received: 907
15 Nov 2020 10:39 #189464
by snowgoer540
I would love to hear thoughts on this. Redoing the changes every time you update is a PITA.
Replied by snowgoer540 on topic PathPilot MegaMod
- gerritv
15 Nov 2020 11:46 - 15 Nov 2020 11:48 #189466
by gerritv
I think a combination of 'diff -c' and 'patch' would work if doing an update on regular basis.A script with only the files we know were enhanced for these features would reduce the output to validate visually.
From 2.0.1 to 2.6/7 would likely be a more manual effort. But then again many of the files have only relatively minor changes per release.
The first thing I would love to know/hear about is how Glade was set up for this effort.
gerrit
gerrit
Last edit: 15 Nov 2020 11:48 by gerritv.
- my.cnc.brother
- Thank you received: 25
16 Nov 2020 15:10 #189548
by my.cnc.brother
Replied by my.cnc.brother on topic PathPilot MegaMod
In my opinion maintaining PP updates after mod is nearly impossible. I had to freeze updates afterwards. Changes between updates can be huge - new or changed files, new machines, complete system loading rebuild and new LinuxCNC compilation files.
I can live without it anyway.
- lrak
- Thank you received: 22
16 Nov 2020 17:43 #189559
by lrak
Replied by lrak on topic PathPilot MegaMod
I discovered nativeCAM the other day.
If there is someone that has played with both PP and NativeCAM - ?
Like to hear what you think of the differences..
- Dorro1971
16 Dec 2020 17:20 #192209
by Dorro1971
Replied by Dorro1971 on topic PathPilot MegaMod
hi,
Great work on the screens!
I have question though, are your modifications carried out in code, glade or something else?....
I can't seem to get glade to open my pathpilot screens without getting upset...
cheers!
cheers!
- gerritv
16 Dec 2020 20:35 #192216
by gerritv
There is one or more threads recently updated on getting Glade and Pathpilot working together. You need glade-gtk2 for starters.
Gerrit
Gerrit
The following user(s) said Thank You: Dorro1971
- Vmax549
- Thank you received: 28
17 Dec 2020 12:55 #192268
by Vmax549
Replied by Vmax549 on topic PathPilot MegaMod
I tried teh method you mentioned and it did not work. I have yet to see a working example of a PathPilot Screen mod where things like adding a new button were done.
Would love to see a Video on HOW to make it work.
TP
- Dorro1971
13 Jan 2021 17:22 #195269
by Dorro1971
Yeah me too....
I suspect it's coding exercise and gtk will be just for viewing..I thought I'd cracked it but no dice!
- gerritv
13 Jan 2021 19:42 #195279
by gerritv
Dorro1971, Is there a way to connect with you directly? I'm on IG as gerrit1857 if that helps. It works for me, although the process once you get Glade operational is shall we say quite obtuse. The whole thing makes me glad I (used to) develop on Windows.
Gerrit
Gerrit
