stop G01 when spindle stop ?
16 Dec 2020 00:31 #192104 by dinkata
stop G01 when spindle stop ? was created by dinkata
Lathe PathPilot 2.1 , 5i25 +7i77 , non Tormach machine .
the situation is like this :
spindle stopped, but operation G 01 continues !
If in MDI ...G01 X-50 F20 ...works without spindle rotation !
How to stop movement G01 if the spindle does not rotate ?
Thanks !
16 Dec 2020 02:30 #192111 by Aciera
Replied by Aciera on topic stop G01 when spindle stop ?
Not sure if this is available on your version but this would be available in 2.8:
motion.feed-inhibit IN BIT
When this pin is TRUE, machine motion is inhibited (this includes jogs, programmed feeds, and programmed rapids, aka traverse moves).
If the machine is performing a spindle synchronized move when this pin goes TRUE, the spindle synchronized motion will finish, and any following moves will be inhibited (this is to prevent damage to the machine, the tool, or the work piece).
If the machine is in the middle of a (non-spindle synchronized) move when this pin goes TRUE, the machine will decelerate to a stop at the maximum allowed acceleration rate.
Motion resumes when this pin goes FALSE.
16 Dec 2020 02:50 #192112 by dinkata
Replied by dinkata on topic stop G01 when spindle stop ?
Thanks, decided with G95
Time to create page: 0.108 seconds
