- User Interfaces
- Other User Interfaces
- PathPilot
- new pp install - screen goes black after select boot option
- blitz355
03 Jan 2021 15:00 #193989
by blitz355
new pp install - screen goes black after select boot option was created by blitz355
I'm in the early phases of swapping my emco lathe equipped with a cnc4pc c11 board that I just added a 7i92 mesa board to. I installed PP to the computer, and after reboot and selecting 'launch path pilot' from the boot option screen, screen goes black and nothing happens.
Are there any obvious areas I'm missing or is it my computer? On a recent post someone made it sound like PP wont boot without a mesa board connected. I have the board connected via the ethernet.. but I haven't flashed it with anything manually.
Thank you for any insight you may have
- smgvbest
- Thank you received: 51
03 Jan 2021 15:37 #193992
by smgvbest
Replied by smgvbest on topic new pp install - screen goes black after select boot option
Make sure EFI is enabled in your BIOS.
Hopefully that’s all it is
- gerritv
- Thank you received: 16
03 Jan 2021 15:45 #193993
by gerritv
Replied by gerritv on topic new pp install - screen goes black after select boot option
The OS will boot without a Mesa card connected. Pathpilot will also try to start but won't complete startup without the card (you will get messages saying there is no connection to the card).
- smgvbest
19 Jan 2021 17:44 #195944
by smgvbest
yeh, he's not getting that far
after you get the grub menu you can select which kernel to load. after he selects the kernel the screen goes black.
one issue is EFI as I mentioned
another is an unsupported video card
either can cause this symptom
you can boot with a basic VGA driver and if that works then its video related
theres a parm you can pass to grub to fix the video. I don't recall what it was but it was discussed here in this group previously
- Thank you received: 7504
19 Jan 2021 18:19 #195952
Replied by tommylight on topic new pp install - screen goes black after select boot option
Try this:
www.dell.com/support/kbdoc/en-al/0001238...on-for-linux-booting
If you do not get the GRUB screen, hold down SHIFT button after the BIOS screen or after pressing the power button on the PC.
The following user(s) said Thank You: smgvbest
- smgvbest
19 Jan 2021 18:33 #195957
by smgvbest
Yep thats the one I was thinking of
- User Interfaces
- PathPilot
Time to create page: 0.131 seconds
