motion.spindle-at-speed behaviour
19 Apr 2021 03:53 #206366 by rafferty
motion.spindle-at-speed behaviour was created by rafferty
My spindle cotrolling hardware has an "at_speed" output which comes in on a 5i25 GPO and connects directly to motion.spindle-at-speed.
when I run this:
G00 X 0 Y 0
S500
M03
F200
G01 X 25
S1000
G01 X 50
M05
M02
Rapid motion X 0 Y 0, a pause till stable 500 RPM is reached then feed rate motion to X 25. All good so far, but then feed motion just continues to X 50 while the spindle accelerates to 1000 RPM, I was expecting a pause while the spindle came up to speed.
The hardware input and motion.spindle-at-speed are tracking the spindle speed changes, inactive when spindle RPMs are changing and active RPMs are stable.
The HAL man page MOTION(9) says;
spindle.M.at−speed IN BIT
Motion will pause until this pin is TRUE, under the following conditions: before the first feed move after each spindle start or speed change; [deleted spindle sync and CSS part]
I there something else needed to get the man page behaviour?
Also, the man page talks of spindle numbers "spindle.M.<pin-name>" but a halcmd show just shows "spindle.<pin-name>"
Am I missing something?
Ken
20 Apr 2021 18:25 #206586 by andypugh
Replied by andypugh on topic motion.spindle-at-speed behaviour
Are you reading the manual for the version of LinuxCNC that you are using?
Though spindle.pin-name is not something that has ever been usual. motion.spindle.pin-name has become spindle.0.pin-name in 2.8 onwards.
20 Apr 2021 18:26 #206587 by andypugh
As for the actual behaviour, have you checked if the spindle-at-speed pin goes false at the speed shift?
21 Apr 2021 08:18 #206640 by rafferty
Replied by rafferty on topic motion.spindle-at-speed behaviour
No, which could well be the problem. I was looking at man pages dated 2021-04-15, which is a lot later than Pathpilot 1.
Yes, the at_speed pin goes false when the RPMs are changing and true when stable again (hal;show).
PP 1 is getting old, Lucid vintage so I've started the move to PP 2 (again). Not hard to do, I can run my mill on a clean install of PP2, just need to change the ini SCALEs. It's making the computer 'nice' and installing all the other things I run on it that put me off.
There are significant (to me) differences between Pathpilot 1 and 2 as well, ".so" versus ".ko" hal modules, it's not "run-in-place", and the "other" sort of kernel. Some of which cause me some confusion.
I'll sit on the at-speed problem until I get sorted again.
Thanks for you assistance with my difficulties.
Ken.
21 Apr 2021 18:14 #206736 by andypugh
Do you know how PP2 and PP2 map on to LinuxCNC versions?
Is PP even LinuxCNC. or is it Machinekit?
21 Apr 2021 19:44 #206750 by Vmax549
Replied by Vmax549 on topic motion.spindle-at-speed behaviour
PP2 seems to be about 50% linuxcnc coding and 50% tormachs own coding.
Just a thought, (;-) TP
21 Apr 2021 21:12 #206757 by rafferty
Collective wisdom here says it's LlinuxCNC, I know nothing of Machinekit, visted the website first time today.
In much poking around I've never seen a mention of Machinekit.
PathPilot 1 is LinuxCNC 2.6.0~pre and kernel 2.6.32-rtai
PathPilot 2 is LinuxCNC 2.8.0~pre1 and kernel is 4.11.9-rt7 REEMPT
Vmax549
Only the PathPilot UI is tormach's work, I think the rest is pure LinuxCNC. The UI is a substantial piece of work all the same. I only wish they didn't feel the need to strip out all the bits they don't need from both LinuxCNC and the underlying Linux.
Ken.
23 Apr 2021 17:41 #206893 by andypugh
I asked Tormach tech support. They didn't know :-/
23 Apr 2021 19:11 #206903 by rafferty
Well that inspires confidence!
I've had some a small amount of contact with them and they were informative and pleasant.
Downloaded Machinekit just for a look, it appears to be LinuxCNC rebranded with a bit of renaming and soft linking.
Ken
11 May 2021 04:38 #208531 by rafferty
Have done a bit more testing of motion.spindle-at-speed. With this program:
G21
S400
M03
G00 X 0 Y 0
F100
G01 X 10
S1000
G01 X 20 Y10
M02
table motion pauses for a very short fraction of second at the speed change and then continues as the spindle accelerates to 1000RPM.
Added some dwell time to force a pause at the speed change:
G21
S400
M03
G00 X 0 Y 0
F100
G01 X 10
S1000
G04 P 1.0
G01 X 20 Y10
M02
this works, table motion stops at the speed change, waits for a stable 1000 RPM, then the motion continues. My spindle takes much longer than the 1 second dwell time to change from 400 to 1000RPM, more like three seconds. The pause appears to trick LinuxCNC into honouring the motion.spindle-at-speed input.
Now I wanted to find the minimum dwell time that would result in the correct (documented) motion.spindle-at-speed behaviour.
A dwell of 0.1 seconds doesn't work, neither does 0.15 seconds but 0.2 seconds does.
What's the significance of 0.2 second dwell?
This is with PathPilot version 1, LinuxCNC 2.6.0~pre and kernel 2.6.32-rtai.
I do really have to get my act together and update.
Time to create page: 0.138 seconds
