- Thank you received: 1480
Have you checked or adjusted the servo tuning using Teknic's software yet?I know this is an old thread, but I have a 2020 1100MX, with the same issue.
Has there been a solution to this issue?
BSAT
Do the other folks you're talking about also have 1100MX's? Just making sure it's an apples-to-apples comparison.I have used the Teknic software and run an auto tune and it helped but the problem still exits.
I havent changed the step input resolution settings(which is 3200 steps/rev) because other folks have no problem nor should I. I can see a tuning change being needed per machine but not a reconfig of input vs resolution.
