- Thank you received: 907
Otherwise, I have had really good response from Tormach with emailing them ideas and beta testing. You might try opening some discussion with them if it's worth it to you.
So far NOTHING can be done in HAL to stop it as it is based in the core of LinuxCNC. But you are welcome to try to. THe only way so far was to use
motion.mode and that gives a value of 5 for probing BUT that is a value and the or2 requires a bit so there is no way to compare the two in HAL
Late update, but Andy's method is working quite well.
Code:loadrt demux personality=7 loadrt conv_s32_u32 loadrt and2 count=1 ... addf demux.0 servo-thread addf conv_s32_u32.0 servo-thread addf and2.0.servo-thread ... net m-type motion.motion-type conv_s32_u32.0.in net m-type-u conv_s32_u32.0.out demux.0.sel-u32 net probing demux.0.out-05 and2.0.in0 net probe-pin {your probe source) and2.0.in1 net checked-probe and2.0.out motion.probe-input
