THe main problem is larger machine always create a resonate freq that tends to rattle the limit switches. The main culprit is teh Z top limit and seeing how with a BP CNC the quill IS a ballscrew you have to protect the quill from bottoming out on the high limit it HAS to be there.
ALSO there are times where we preload things while the machine is running like changing out the probe or tool setter. IF you do that in PP then it trips the machine offline and stops.
The function is really a silly function. IF you want it it should be an option you can turn ON/OFF with a mcode. THe normal function should default to OFF then you can turn it ON when you want it.
What I have to do now is to use a pair of relays to BLOCK the probe / toolsetter signals . For each probe I have to crowbar across the inputs so that PP thinks there are not active. BUT when you need to use the probe /toolsetter you have to REMEMBER to release the relay so PP can see the signals again.
NO ONE in teh CNC world does it like Linuxcnc is doing it. (;-(
TP
