Override +- 10% buttons
2 years 11 months ago #285559 by Dorro1971
Replied by Dorro1971 on topic Override +- 10% buttons
Hi Vmax549,
did you get round to finishing the code?...
i was thinking about using something like
variable =self.sliders.adjustment.get_value()
but im not sure of the syntax or what the feed_rate slider is called....
If you have a solution that can be activated from a key press I'm all ears!
I tried generichid and it works but it hogs the usb at 50ms poll rate and I don't like the mpg jog...so i used an arduino as a hid keyboard and placed jog speeds, step sizes, cont or inc in tormach_mill_ui.py and used the mpg encoder frequency to change speeds..or step forwards/backwards..works really well and doesn't hog the usb...adding feedrate, spindle and maxvel via keys would be the finishing touch....
Can you or anyone else help me out?...I had help a while ago from yourself and snowgoer540 but sadly i lost all of my email contacts...
Thank you in advance...
dorro
2 years 11 months ago - 2 years 11 months ago #285891 by Dorro1971
this works for me..i will send keystrokes from an arduino hid keyboard using three panel encoders to send increment or decement...
# search for "self.sliders.update({" in mill or lathe ui.py             # ------------------------------------------------             # Sliders             # ------------------------------------------------             self.sliders.update({                 "spindle": ui_support.OverrideSlider(                     adjustment=self.builder.get_object("spindle_override_adjustment"),                     scale=self.builder.get_object("spindle_override_scale"),                     label=self.builder.get_object("spindle_override_label"),                     button_100=self.button_list['spindle_override_100'],                     prefix="S",                     value_source_cb = lambda: self.hal['console-rpm-override'] * 100.0,                     lcnc_apply_function=lambda value: self.command.spindleoverride(value / 100.0)                 )             })             self.sliders['spindle'].set_slider_value(100)             self.init_sliders() #add this line             self.override = [100,100,100] #new list for override variables, set them to 100% #search for "# Escape key for stop" #add after the block below             # Escape key for stop             if kv == gtk.keysyms.Escape:                 self.error_handler.log("ESC key - queueing stop button event")                 self.enqueue_button_press_release(self.button_list['stop'])                 self.tool_descript_entry.shutdown_view()                 tooltipmgr.TTMgr().on_esc_key()                 return True # add incement and decrement via keys             if kv == gtk.keysyms.a:                 self.override[0] = self.override[0] + 5                 if self.override[0] > 200:                  self.override[0] = 200                 self.sliders['spindle'].set_slider_value(self.override[0])                   return True                if kv == gtk.keysyms.b:                 self.override[0] = self.override[0] - 5                 if self.override[0] < 0:                  self.override[0] = 0                 self.sliders['spindle'].set_slider_value(self.override[0])                   return True                if kv == gtk.keysyms.c:                 self.override[1] = self.override[1] + 5                 if self.override[1] > 200:                  self.override[1] = 200                 self.sliders['feedrate'].set_slider_value(self.override[1])                   return True                if kv == gtk.keysyms.d:                 self.override[1] = self.override[1] - 5                 if self.override[1] < 0:                  self.override[1] = 0                 self.sliders['feedrate'].set_slider_value(self.override[1])                   return True             if kv == gtk.keysyms.e:                 self.override[2] = self.override[2] + 5                 if self.override[2] > 100:                  self.override[2] = 100                 self.sliders['maxvel'].set_slider_value(self.override[2])                   return True                if kv == gtk.keysyms.f:                 self.override[2] = self.override[2] - 5                 if self.override[2] < 0:                  self.override[2] = 0                 self.sliders['maxvel'].set_slider_value(self.override[2])                   return True #this works well as long as thenkeyboard is used, if the sliders are used then the variables are not updated, #the still slider works but the next time the keybaord is used a large step may result as the variable is #still set to the last value used by the keyboard Hope this helps someone... Ian
Last edit: 2 years 11 months ago by Dorro1971.
Time to create page: 0.046 seconds
