Override +- 10% buttons
08 May 2023 08:13 #270909 by Vmax549
Override +- 10% buttons was created by Vmax549
Has anyone done override  + / - 10% buttons yet  for PathPilot ???
(;-) TP
08 May 2023 11:19 #270920 by Vmax549
Replied by Vmax549 on topic Override +- 10% buttons
OK I see how to change the value of the sliders BUT I do not see a way to get the current value of the slider. Any Ideas or hints ??
(;-) TP
08 May 2023 12:34 #270923 by nick.smith
Replied by nick.smith on topic Override +- 10% buttons
This is a janky way to do it, but on my Shortcuts page, I'm doing sliders at 0%, 20%, 50%, 100%, etc by mousemoving to a specific xy coordinate, then dragging to a specific xy coord.
Since they are bash scripts, you can store and retrieve the location you traveled to, which can be interpolated as the slider percentage.
08 May 2023 12:36 #270924 by nick.smith
Also, I've been told by the mfg that the current location of the slider isn't located anywhere, which is bollocks, but I have found that if you mousemove fast enough (which xdotool definitely can do), resetting the slider to 100%, then moving to another percentage happens so fast the machine doesn't notice.
For example, if you're at 50% and want to go to 40%, I haven't figured out how to find if the slider is at 50% or not (retrieving a previously stored value would do it, but I haven't written that code yet), BUT you can reset it to 100%, then travel to 40% so fast that the machine doesn't notice.
08 May 2023 17:52 #270948 by Vmax549
OK, I found the current override values in the Hal section. So now to make a new set of hotkeys
Feed +10%
Feed-10%
speed+10%
speed-10%
m_vel +10%
m_vel-10%
(;-) TP
08 May 2023 19:34 #270951 by Vmax549
I now have hotkeys that adjust the overrides +/- 10% each push. I will post the code to the toolbox after some more testing.
Getting closer to mouse free every day, (;-) TP
28 Sep 2023 09:51 #281780 by DestructiveSoul
Replied by DestructiveSoul on topic Override +- 10% buttons
Wow! this is awesome!! are you able to share how you did this? The mouse is making me crazy lol..
28 Sep 2023 09:58 #281782 by tommylight
Replied by tommylight on topic Override +- 10% buttons
Axis GUI in LinuxCNC has +-10% buttons out of the box, numbers from ~ to 0 , yes tilde is 0% so the machine will not move 1=10%, 2=20% ..... 0=100%.
Can any of you try that on PathPilot and report back, please.
28 Sep 2023 11:14 #281787 by snowgoer540
Replied by snowgoer540 on topic Override +- 10% buttons
It does not work Tommy, Tormach has very few keyboard shortcuts mapped in PathPilot.
28 Sep 2023 11:58 #281788 by nick.smith
I am close to mouse-free:
tormachtips.com/shortcuts.htm
Looks sort of janky, but you can set this up however you want and write shortcuts for whatever you want. I cannot and will not use my machine without my shortcuts. 100%, total game changer.
Time to create page: 0.284 seconds
