Override +- 10% buttons
- DestructiveSoul
28 Sep 2023 21:00 #281817
by DestructiveSoul
Replied by DestructiveSoul on topic Override +- 10% buttons
Hi Nick! I had a look at your stuff! Fantastic job!! you have done something really cool! I think i will start my own keypad! thanks for sharing!
- Dorro1971
- Thank you received: 16
16 Nov 2023 00:30 - 16 Nov 2023 00:32 #285558
by Dorro1971
Replied by Dorro1971 on topic Override +- 10% buttons
added by mistake!
Last edit: 16 Nov 2023 00:32 by Dorro1971.
- Dorro1971
16 Nov 2023 00:33 #285559
by Dorro1971
Hi Vmax549,
did you get round to finishing the code?...
i was thinking about using something like
variable =self.sliders.adjustment.get_value()
but im not sure of the syntax or what the feed_rate slider is called....
If you have a solution that can be activated from a key press I'm all ears!
I tried generichid and it works but it hogs the usb at 50ms poll rate and I don't like the mpg jog...so i used an arduino as a hid keyboard and placed jog speeds, step sizes, cont or inc in tormach_mill_ui.py and used the mpg encoder frequency to change speeds..or step forwards/backwards..works really well and doesn't hog the usb...adding feedrate, spindle and maxvel via keys would be the finishing touch....
Can you or anyone else help me out?...I had help a while ago from yourself and snowgoer540 but sadly i lost all of my email contacts...
Thank you in advance...
dorro
dorro
- Dorro1971
19 Nov 2023 13:09 - 19 Nov 2023 13:25 #285891
by Dorro1971
this works for me..i will send keystrokes from an arduino hid keyboard using three panel encoders to send increment or decement...
# search for "self.sliders.update({" in mill or lathe ui.py
# Sliders
"spindle": ui_support.OverrideSlider(
adjustment=self.builder.get_object("spindle_override_adjustment"),
scale=self.builder.get_object("spindle_override_scale"),
label=self.builder.get_object("spindle_override_label"),
button_100=self.button_list['spindle_override_100'],
prefix="S",
value_source_cb = lambda: self.hal['console-rpm-override'] * 100.0,
lcnc_apply_function=lambda value: self.command.spindleoverride(value / 100.0)
self.sliders['spindle'].set_slider_value(100)
self.init_sliders()
#add this line
self.override = [100,100,100] #new list for override variables, set them to 100%
#search for "# Escape key for stop"
#add after the block below
if kv == gtk.keysyms.Escape:
self.error_handler.log("ESC key - queueing stop button event")
self.enqueue_button_press_release(self.button_list['stop'])
self.tool_descript_entry.shutdown_view()
tooltipmgr.TTMgr().on_esc_key()
return True
# add incement and decrement via keys
if kv == gtk.keysyms.a:
self.override[0] = self.override[0] + 5
if self.override[0] > 200:
self.override[0] = 200
self.sliders['spindle'].set_slider_value(self.override[0])
return True
if kv == gtk.keysyms.b:
self.override[0] = self.override[0] - 5
if self.override[0] < 0:
self.override[0] = 0
return True
if kv == gtk.keysyms.c:
self.override[1] = self.override[1] + 5
if self.override[1] > 200:
self.override[1] = 200
self.sliders['feedrate'].set_slider_value(self.override[1])
return True
if kv == gtk.keysyms.d:
self.override[1] = self.override[1] - 5
if self.override[1] < 0:
self.override[1] = 0
return True
if kv == gtk.keysyms.e:
self.override[2] = self.override[2] + 5
if self.override[2] > 100:
self.override[2] = 100
self.sliders['maxvel'].set_slider_value(self.override[2])
return True
if kv == gtk.keysyms.f:
self.override[2] = self.override[2] - 5
if self.override[2] < 0:
self.override[2] = 0
return True
#this works well as long as thenkeyboard is used, if the sliders are used then the variables are not updated,
#the still slider works but the next time the keybaord is used a large step may result as the variable is
#still set to the last value used by the keyboard
Hope this helps someone...
Ian
Last edit: 19 Nov 2023 13:25 by Dorro1971.
Time to create page: 0.299 seconds
