Hostmot2 firmware
3 years 3 months ago #275099
by Cyber
Hostmot2 firmware was created by Cyber
Hello,
I'm using a Tormach machine with a Torstep board, I have noticed that the board has an STM 32 microcontroller on it. my question is does Hostmot2 firmware support the microcontroller since it's designed for FPGA?
3 years 3 months ago #275101
Replied by PCW on topic Hostmot2 firmware
What hardware driver is is launched in the hal file?
3 years 3 months ago #275136
by Cyber
Replied by Cyber on topic Hostmot2 firmware
this is the content from the hal file. it doe load Hostmot2.
# Tormach xsTECH router HAL config for Torstep control board
loadrt trivkins
loadrt [EMCMOT]EMCMOT servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[TRAJ]AXES num_dio=64 num_aio=64
loadrt hostmot2
loadrt [HOSTMOT2]DRIVER [HOSTMOT2]DRIVER_PARAMS
loadrt estop_latch
loadrt toggle count=1
loadrt not names=prog-not-idle
loadrt gearchange count=1
loadrt xor2 names=probe-active-hi-lo
loadrt debounce cfg=5
loadrt pid num_chan=4
loadrt tormachspindle names=tormachspindle
loadrt and2 names=enable-limit-z,probe-enable-input,door-limit-in,y-axis-lim-sw-and2,fake-door-lock,limit-x,limit-y,limit-z,fake-probe2
loadrt lut5 names=door-limit-x-lut,door-limit-y-lut
loadrt dspin
loadrt trivkins
loadrt hostmot2
loadrt estop_latch
loadrt dspin
3 years 3 months ago #275137
Looks like they emulate hostmot2 in the STM32
(you might look in the .ini file to see if they use the hm2_eth hardware driver)
The following user(s) said Thank You: Cyber
3 years 3 months ago #275142
by Cyber
thank you so much for your response, they do use hm2_eth in the .ini file.
so what do you mean by emulating hostmot2 in the STM32? I noticed the board has a micro USB interface on it. do you you have any idea how I can push the firmware to the controller?
3 years 3 months ago #275143
You would have to ask Tormach any specific questions related to their hardware.
Time to create page: 0.268 seconds
