PathPilot 2.9.6 on non-Tormach machine
2 years 8 months ago #292271 by B.Reilly01
That's a much better idea than the wall I've been beating my head against
2 years 8 months ago - 2 years 8 months ago #292352 by B.Reilly01
okay, I'm getting further. Now LinuxCNC starts to load when the board fails "HM2 registration", then rtapi_app_main: Invalid argument (-22), then some other fails and it shuts down. I came to realize that PP2 is based on Linuxcnc2.8.0~pre1 and support for the 7i97T was added to 2.9.1. I wonder if there's a way to upgrade the background linuxcnc version to 2.9.1?
wrote rtapi_app pid 2924 to /sys/fs/cgroup/cpuset/rt/tasks hm2: loading Mesa HostMot2 driver version 0.15 hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.3 iptables: No chain/target/match by that name. hm2_eth: 10.10.10.10: Hardware address: 00:60:1b:17:80:02 hm2_eth: Unrecognized ethernet board found: 7I97T -- port names will be wrong hm2_eth: discovered 7I97T hm2/hm2_7i97.0: Smart Serial Firmware Version 43 Board hm2_7i97.0.7i76.0.0 Hardware Mode 0 = standard Board hm2_7i97.0.7i76.0.0 Software Mode 0 = io_spin Board hm2_7i97.0.7i76.0.0 Software Mode 1 = io_ana_spin Board hm2_7i97.0.7i76.0.0 Software Mode 2 = io_enc_ana_spin_fv hm2/hm2_7i97.0: inconsistent Module Descriptor for PWMGen, not loading driver hm2/hm2_7i97.0:     Version = 1, expected 0 hm2/hm2_7i97.0:     NumRegisters = 5, expected 5 hm2/hm2_7i97.0:     InstanceStride = 0x00000004, expected 0x00000004 hm2/hm2_7i97.0:     MultipleRegisters = 0x00000003, expected 0x00000003 hm2/hm2_7i97.0: inconsistent Module Descriptor! hm2/hm2_7i97.0: failed to parse Module Descriptor 7 board fails HM2 registration hm2_eth: rtapi_app_main: Invalid argument (-22) basic7i97.hal:11: waitpid failed /home/operator/tmc/bin/rtapi_app hm2_eth basic7i97.hal:11: /home/operator/tmc/bin/rtapi_app exited without becoming ready basic7i97.hal:11: insmod for hm2_eth failed, returned -1 HALCMD ini file /home/operator/tmc/configs/tormach_mill/Basic7i97-1.ini load failed with config file basic7i97.hal Shutting down and cleaning up LinuxCNC... 2913 Killing linuxcncsvr Killing task linuxcncsvr, PID=2913   PID TTY      STAT   TIME COMMAND 1805
Last edit: 2 years 8 months ago by B.Reilly01. Reason: Added relevant log section
2 years 8 months ago #292377 by tommylight
In a terminal
python -v
Will show the Python version used.
2.8 is when everything moved from python 2 to python 3, so upgrading might not work if it is on python 2.
Also, what does
lsb_release -a
Return?
ASUS ROG Crosshair VIII Impact - AMD X570
2 years 8 months ago #292380 by B.Reilly01
Yeah. so this project is probably dead... python 2.7.
PP2 is built on Linux Mint 17.3 Rosa
2 years 8 months ago #292389 by tommylight
Does PathPilot have anything more recent?
Other solutions would be a 7i92 (without T as 7i92T might also not work, it is new), or 5i25 or 6i25, since you also have a 7i76.
And if you need analog (probablu do as 7i97 is) use a 7i83 and a 7i85 for encoder feedback.
That does imply a lot of editing, so weigh in the pros and cons before jumping in.
Sorry for not being able to help more but i never used PP, this is just what i gathered from reading this forum.
2 years 8 months ago #292427 by B.Reilly01
I currently have the most recent version of pathpilot (2.10.1), and this is what it's built on... I'm considering a 7i92 & 7i77&7i76, as I do need analog servo interface and I already have the 7i76 for IO. Before I go and jump into even more hardware, I'll wait a little to see if anyone else sees something different in the log (attached). I'm not a software guy, so I'm grasping at straws here. Perhaps Pathpilot can support the 7i97T. (Wishful thinking, I know). I appreciate all the help you've given me. I just wish the 5i25/7i77 was available back when I started this journey, I would've gone that route. I know the 5i25 is supported by Path Pilot.
Time to create page: 0.484 seconds
